Denali132
Banned
You definitely got ripped off because I've seen LTs on the lot and all had covers on them. I'm not sure about the LS models though .
Sent from my iPad Pro using Tapatalk
Rdr854
Northern VA
I'm happy not to have the hitch cover. Just one more thing to deal with when I want to put a bike rack on. And g-d forbid that I break one of the tabs that secures it in place like one of my neighbors.
el_flores
Just go ahead and send it to me, I'll get it out of your way!
ajs800
Michigan
Had Michelin Defenders installed in the oem 275/55/20 size. Had Michelin Premier LTXs prior and they only lasted 26k...The defenders seem to have a much better ride and look much better!
empire_designs
I went ahead and did the headlight switch mod to keep my HID lights off until I actually need them. Basically removed the spring in the switch to allow the knob to rest in the off position.
Has there been issues with the bulbs burning out prematurely or is this a purely asthetics mod? Ie, do you just prefer not to have auto DRL?
UnitedStites
Hi – no, I have not had an issue with the bulbs burning out, but I did feel that the HID headlights were a little too much for daytime.
DWTahoe
Colorado
I went ahead and did the headlight switch mod to keep my HID lights off until I actually need them. Basically removed the spring in the switch to allow the knob to rest in the off position. View attachment 83110 View attachment 83105View attachment 83106View attachment 83107
I had no idea this was something that could be done, I really like that. Do you have a more detailed write up someplace? Any more specific details you can provide would be great.
Thanks.
UnitedStites
1badtahoe24
hmm, i understand why you did it, but couldn't you just turn them off when you drive during the day...same thing as turning them on at night right??? But to each their own.
DWTahoe
Colorado
Agreed...I'd rather have the DRL default to the off position and then turn them on when I want them. I rarely want them on.
I believe the original reason they were setting them to off was because the duramax guys had replaced their DRL with HID's and apparently the constant on and off is ******* the lights and causing them to burn out early.
AZCreeker
Yesterday we had the lower rear springs removed. Put the stock one back on and got some
Midnight edition z71 wheels along with some 275/65r18 Goodyear Sr/a tires
3 re picture was how it was prior
16blkltz
Hodmjstone
