Parasitic Draw
Dlayne
Bend, OR
Just wondering if anyone else has had a similar issue.
If the vehicle sits for more than two days, the battery is completely dead. Has happened about 6 times (only 6 times with it sitting that long). 2017 Yukon Denali XL with 5,800 miles. No aftermarket electronics or chargers plugged in. Dealer looked at it once already and said battery and charging system was OK. Key has not been left in it either. Back to dealer for this again and for a horribly squeaky rear suspension.
Thanks.
Denali132
Banned
Mine has sat a few days and it starts up fine. Has it only done this once? If any interior lights are left on they automatically turn off after I believe 10 minutes which I love because my kids have left them on a few times! For it to kill your battery it must have been something drawing some current because a new vehicle should not be going dead!
Sent from my iPad Pro using Tapatalk
Dlayne
Dlayne
Bend, OR
It has happened about 6 times which is everytime it has been parked for 2-3 days. Agreed new vehicle should not do this! Nothing left on. No kids at home:) It goes into "sleep" mode like it should and you would think that would prevent the draw-down. That's why it's so puzzling.
Naz 23 Esky
Ontario Canada
I have the same issue with the squeaky rear suspension, going in on Monday to look at wonder if it's the same issue you have.
Denali132
Banned
I always hated when something was wrong with one of my vehicles and I would take it in and it wouldn't show up! I think they believe we are making it up or something and then as soon as I pulled away or got home it would act up again. They would say sorry there's nothing we can do because it won't do it while they had it or something like that. Has it only happened the one time?
Sent from my SAMSUNG-SM-G935A using Tapatalk
Kpwweb
Thanks.
Did your vehicle sit awhile before you bought it? Battery could have died then--once they are pretty discharged, they don't come back the same. How is the dealer testing? Do they put it under load?
Also, squeaky rear suspension is probably the parking brake cables--another victim of sitting awhile--the outer cover can get a bit of surface rust and get squeaky. There is another post somewhere in here on where they get squeaky and where to spray lubricant. Pretty much look where they have to flex and you'll find the spots, Works very well.
Have fun!
Dlayne
Dlayne
Bend, OR
Have fun!
Thanks. Good info.
According to the buildsheet and dealer info. it was shipped a week after build and was only on the lot for about 20 days. I was chasing a Unicorn (Summit White, tan interior and retractable running boards). A garage Queen since I brought it home. Just wrong for a $82k MSRP vehicle (but my 4th Denali so the product fits) to sound like and old boat trailer going down the road.
Yes, wondering if the battery is shot after the discharges. Stock battery is pathetic, compared the the AGM batteries I normally put in.
Hope to not "Have fun"..lol
Dlayne
Dlayne
Bend, OR
Agreed. I know the dealer will find everything OK so my plan is to delay picking it up for 3-4 days and then when it takes them 20 minutes to retrieve it from the back lot I can ask "what took so long? Battery dead?"
Batterycap
I have the same thing going on with a 2001 Suburban that I brought back from an ignored state. I had a new Pioneer system pro installed - next to top of the line, and the problem started. However, we have traced all back through and see no current draw. By the way, a new battery was installed. If it sits more than a day or 2, its dead. My immediate solution was to buy a a Jump N Carry. It works better than I thought it would. However, it is still a pain to have to jump her off every now and then. If I ever figure it out, I will post the solution.
Alexquade
Crowley, LA
Not sure what your squeaking could be, and I know it's two totally different monsters, but my 11 Yukon xl was squeaking like freaking crazy over bumps. I thought it was seats not seated, they were fine, next was the hatch/glass. Checked the glass and when I opened it squeaked. Figured hinges. Totally wrong. The damn center bolt for the third brake light came loose. Tightened it down and squeak is gone!!! :chewie:
PG01
Up here to the right
I would get a new battery.
When I bought my '13 tahoe battery would die on occasion especially since its sits in the garage all week and is mostly driven on the weekends. I had to bring it in for warranty work a few months into owning it and that morning it was dead in my garage, (i was pissed because it was 430am and i didnt feel like dealing with that crap) i jump pack started it and drove to dealer.... they called me and said i needed a battery because they couldn't even get it to crank...new battery under warranty but it was dinky compared to what was in there.... and no problems since then.
i went to sears last year and bought 2 diehard gold batteries and hooked them up for my plow but that battery the stealership put in is still good and on a trickle carger in my garage.
Point is get a new battery....
TahoYukon Forum
Try hooking a volt meter between power cable and battery and check amp draw, then recheck after disconnecting starter (should not have any draw.
Had faulty starters on a few vehicles that did this very same thing.
Or, connect voltmeter with batt Conn., Then remove 1 fuse at a time to eliminate circuits. Hope u get this fixed, it's gotta be annoying yo. :^)
My99Yukon
you might have to pull some carpet but the ground on the amplifier, if you have one, could be poorly connected. I had a 300 amp installed several years ago and I finally pulled up all the wiring and found a rat's nest terrible install so I rewired it, took the paint off the grounding point and reinstalled. The sound is better and I don't seem to have the same parasitic drain.
Dlayne
Dlayne
Bend, OR
Yep, separate animal. Good to know. This is definitely coming from the driver side rear as it can be recreated by just rocking the vehicle. Probably nothing, but annoying as hell.
Dlayne
Dlayne
Bend, OR
Thanks for the suggestions. Everything still stock, not even a phone charger. Haven't hard wired the radar detector yet just so everything is as it was from the factory. It was dead again this morning after sitting for the weekend in the garage. First time dealer said battery and charging system tested good. It goes back to them next week. I am thinking battery too, but refuse to buy one at this point as the vehicle is only 4 months old!!!!
If they don't find anything wrong when they call me, I will just leave it there at the dealer for a week and then when they go to get it....they can deal with it:)
PG01
1 bad cell in the battery
k5blazerkeith
Our 2016 Yukon XL has same battery problems...dealer replaced it last year with new battery, was fine for a few months, now is happening all over again. Can't even leave the vehicle over the weekend without driving, or it will either be dead on Monday morning or barely start...it was in last month for loose driver's seat and broken latch on the rear cargo cover, and they said they tested battery and charging system, all came out "normal". I've probably jumped the vehicle with my Schumacher battery charger at LEAST 10 times in the year and a half we've had it...pathetic. Now, my driver's side window is crazy - push the button to get the window down, it goes down...but when you push the button to have window go back up, it does, but when the window reaches the top of its travel, it AUTOMATICALLY goes back down! And you can't reverse it, or stop it, it just goes up and down on it's own! Sometimes it stops at the top, most of the time it just keeps going up and down on its own...freaking great! I've got it on video for the dealer, going in for the last complimentary oil change soon. I've had GMs all my life, but this truck is the worst...and to think it was $70k, sad. Too many electronics I guess...glad I lease, I'd never want to be stuck with all these computers to go wrong after warranty.
Dlayne
Dlayne
Bend, OR
I feel your pain!! 4th Denali and can't believe GM can't get the little things right. Been spoiled by the Germans for the other vehicles in our stable when it comes to customer service.
My update to this is well...the same thing you got again! Battery and charging system OK. The other squeaky issue, said it was the e-brake cable and lubed and put in some rubber. Lasted 20 miles. Oh' and our only available dealer, the loners are through Enterprise and must be a GM vehicle (because if I drive a Kia or Hyundai I might change brands) so the only vehicle is a 15 passenger van that smells like a collage road trip. Paid for the Q5 rental myself!
Might just have to go with a double battery system with a Perko switch....very sad....
Dlayne
Dlayne
Bend, OR
Just thought I would give an update. Finally, left it with the dealer for over a week. Of course, they couldn't get it to draw down after sitting inside for the weekend so they moved it outside to their lot. Fortunately, one of my son's friends is a tech there. I asked him if he could go out every other day to try to start it. Wasn't going to pick it up until it died on them. Finally, it died on them several times.
They thought it was connected to the Onstar since it only happened outside for them. Happened inside for me many times. Since, they now knew I wasn't nuts, they actually started testing each circuit like many of you suggested. These are trained professionals. WTF took so long? I know it is tough for them to justify the time to GM if they can't replicate the problem.
Bottom line, they determined the amp keeps coming on, but only intermittently. That would explain the quick draw down. New amp being installed this week. Keeping my fingers crossed.
Thanks for all the replies.
briannorris
