Blackout grill on nbs denali
adventurenali92
Big Bear Lake, ca
Quick ps. I say colormatched grille surround, chrome insert imo.
I like the middle option best on your truck. Everything black except that honey comb in the middle chrome. That looks killer because your truck is black. Just the right amount of black and chrome on your truck.
05Single
afraid of the dark
J-B Weld KwikWeld Quick Setting Steel Reinforced Epoxy
For the damaged struts between the main grille and the turn signal surrounds I just used the epoxy. For the main break in the grille surround I embedded a 1"x4" piece of perforated steel in the epoxy to bridge the area.
Did you sand/scuff it before applying the jb weld?
mals
Western Mass
Not directly, but when I got the grille off I saw that someone had already tried to repair the areas with an epoxy that was not really designed for plastic and had cracked. I scrapped all the existing epoxy off with a dull chisel, so the areas were pretty roughed up when I applied the JB Weld. It may not be necessary, but roughing up the area definitely would be a good idea if you were doing a similar repair.
I did Scotch Brite and then wet sand the the chrome mesh before I painted it. I'm fairly happy with the overall repair, and finding a replacement grille has dropped down to the bottom of the to-do list.
XLDenali06
Southeast Tennessee
That's what I've decided to go with, especially after finding some pics online that have the chrome honeycomb and black surround, with the nnbs black and chrome GMC badge (which I've switched to since the pic used for the PS). Looks great that way, imho. Here's one example I found:
That's what I've decided to go with, slavishly after finding some pics online that have the chrome honeycomb and black surround, with the nnbs black and chrome GMC badge (which I've switched to since the pic used for the PS). Looks great that way, imho. Here's one example I found:
Do you have a p/n for the NNBS badge?
XLDenali06
Southeast Tennessee
Don't know the part number, but here's a link to where I bought mine on Amazon. It's pricey, at $90 ($100 on eBay), but worth it to me. Plus I got like $40 back from Amazon when I returned the solid black emblem, so that took some of the sting out. Definitely cheaper to dip the original though, if you're so inclined. Anyway, here's the link:
https://smile.amazon.com/gp/aw/d/B01KN7B4K4/
adventurenali92
Big Bear Lake, ca
@XLDenali06 , I didn't realize the NNBS grill logo was different than the nbs. I like it alot! Much cleaner with the the obnoxious border! Did it go into your grill without any modification? Thinking I might pick one up and color match it to my truck. It would be easier to color match because it doesn't have the little plastic border surround.
XLDenali06
Southeast Tennessee
I think I may have misspoke when I referred to it as an nnbs emblem. I thought it was an option with those because I've seen quite a few around here that are otherwise stock but with the black emblem instead of the red. But after a little internet sleuthing, all I can find is the one made by All Sales Manufacturing. Anyway, they make several different styling options, all made of billet aluminum. You can get out with or without the chrome border. I originally had the solid black, then switched to the black with chrome border so the emblem didn't get visually lost in the black rectangle it sits on in the middle of the grille. They mount via threaded rods that screw into the back of the emblem at 4 places, go through the grille using existing holes, then it's just a washer and a nut. Hand tightening is plenty. The hardest part is getting to the back side of the grille, obviously you have to remove the fan shroud (that's what I call it anyway, from the days when I had my 92 Roadmaster with its big mechanical fan, it may be called something different now, Idk).
You can just remove the grill itself, it takes about 10 minutes. First remove the headlights by removing the 2 pins on each. Then remove the plastic piece on top that covers the area between the radiator and grill by removing the 8 or so push pins and then remove the grill by removing the 10 mm bolt at the top, then turn the 4 plastic retainers (2 at top, 2 at the bottom) counterclockwise using a #2 Phillips until they stop, about 1/2 turn. Then start at one side by pulling carefully on the clip at the fender and then at the other fender clip. Lift straight out. That way you can lay it down on it's face (with protection) and get to the back easily. It's really simple on our trucks.
XLDenali06
Southeast Tennessee
If your hands are small enough though, it's easy enough to reach back behind it once you've removed the radiator cover (what I referred to as a fan shroud). And takes a little less time that way. Something that is always running short for me. Lol. It's good to know how easy it is though, for when I dip mine black ;-)
HeavyHoe03
