Your 0-60 times
02_Tahoe
Maryland
So just thought this would be a cool thing to do. Say what you got, what mods you have and what your 0-60 is. I'm curious to see what everyone's doing. I didn't really do it the right way but I'll say what I have now and update it tomorrow on if my time changed
02 LS, 5.3L, 3.73 gears, 3 inch lift, 33" mud tires and 18x10 wheels weighing in at 115 per wheel/tire, flow master super 10
Going up hill from a dead stop and without Reving it up I got a 14.2, tomorrow I'll go on flat ground and hold the brake and rev it a bit to see what I can get
Sasquatch
Orange County N.Y.
I`ll have to check with the torque app tomorrow and post what i get. Last time i used it i got a 12 second 1/8 mile but i forget the 0-60 time.
02_Tahoe
02_Tahoe
Maryland
Retried on flat ground from a dead stop with no reving, got 12.1. Still seems kinda slow but I'm getting a tune from black bear performance next weekend. Hopefully it'll get me into the 10s
Maximus1
Yeah right ^^^
Not sure what my 0-60 is. I'll give an update soon. Mods include the following.
BBK 80mm TB
K&N CAI
ELECTRIC FANS
HOWARD CAM 267/276 duration .525/.525 lift
CUSTOM HP TUNE
3.90 GEARS
UPGRADED 4L70E transmission rated at 600+ hp waiting to be installed and will have a 2500 Hughes stall
MSD COILS
SCORPION ROLLER ROCKERS 1:7 RATIO
HEADMAN 1-5/8" primaries headers
799 heads CNC ported waiting on them to return from the machine shop.
Summit Racing mass airflow sensor
FLOWMASTER HIGH FLOW CATS AND FLOWMASTER CATBACK EXHAUST DUMPED BEFORE THE REAR AXLE
EIBACH FRONT AND REAR SWAY BARS
1.5" torsion bar keys to level the Tahoe
I'm probably forgetting a few other mods
about20ninj45
If you can't hit 6 sec 0-60 while Footr braking then something is wrong, but don't come at me like you've been in my vehicle and know what's been done to it. Don't forget, I'm awd
02_Tahoe
02_Tahoe
Maryland
Yeah right ^^^
BBK 80mm TB
K&N CAI
ELECTRIC FANS
CUSTOM HP TUNE
3.90 GEARS
MSD COILS
Damn, your truck sounds bad ass man! Are there any performance gains from the electrical fans
02_Tahoe
02_Tahoe
Maryland
If anything you'd be slower than a 2wd. Your loosing more power to the wheels. Plus you're in a suburban, unless you have an aggressive cam and you have FI, there's no way you're at 5 seconds
EDIT: I see you are FI. But there's no way you can hit 6 seconds in these trucks unless you are FI.
about20ninj45
you know stock 2006 GMC Yukon Denali does 0-60 in 6.1 - 7.2 seconds? 6 liter 3:73 rear and front from the factory? I don't own/drive a suburban. And awd get off the line quicker with more traction than 2wd.
Maximus1
Thanks I really appreciate that. A small amount maybe 15-20 horsepower. I purchased Summit Racing part number FLX-282. The one big improvement was the A/C blows a lot colder even when I'm at a stop. The manual fan doesn't pull enough air at a stop to keep the A/C cold. If you're going to install electric fans, you get what you pay for. Trust me I've already tried to go the cheap route and it works for a while but ends up breaking. I bought this one over two years ago and still runs like new.
Maximus1
The Denali is the same size as a Surburban just overpriced. IMHO and you'd need a lot more than FI to get under 6 seconds. If you can then prove it and post a video with a stopwatch and in view of your speedometer. Kind of a "put up or shut up". I don't even think I can beat 6 seconds 0-60 mph even with all the MODS but I haven't tried either. I will soon and try and post the video.
02_Tahoe
02_Tahoe
Maryland
I just got the in person tune from black bear and justin told me that he tuned it so that if I ever want the e fans that all I need is the fans and the harness. I also tested my 0-60 after the tune, on the same stretch of road and I got 8.44 seconds! I dropped 3.7 seconds with just a tune. Now I know I'll never be able to stop modding
02_Tahoe
02_Tahoe
Maryland
I definitely believe you can get 5 seconds now. I just tested mine again and dropped 3.7 seconds with just a black bear tune. I ran a 8.44 with 33" tires and 3.73s! A stock truck with 30" tires and 4.10s are advertised at 8.6 seconds. I can't wait until I regear to 4.56. Hoping to see that number 6
about20ninj45
6.0 vs 5.3 ??? I'm not on here to prove or disprove anything I don't have anything to gain or lose. When I go to the track I'll post up the time slip and video of the speedo. I typed a 5 instead of a 6. My apologies, but if you need more clarification, you can even fact check what I said. 6.0, 3:73 gears,blower and a 3200 stall is more than enough to get you there.
08grey
He lost two seconds just sleeping at the light.
Sent from my SM-G950U using Tapatalk
dizhai
