Austinite's 2000 NBS Tahoe Ex-Grocery Hauler Build
Austinite
Austin, Tx
I bought this old girl back in Aug 2015. She was pretty rough on the outside, but for having 240K miles she runs decent and the interior ain't too bad besides the typical torn driver's seat bottom. It was a 1 owner and the lady was a soccer mom, so I think she took pretty good care of it.
*bold is the latest updates*
Mods/Fixes So Far:
Engine/Mechanical:
-eBay OBX Racing Style LT Headers W/ Y-Pipe and High Flow Cats
-3 Sets of Dorman Exhaust Manifold Broken Bolt Repair Kits
-Magnaflow 12589 Muffler
-Vacuum Actuated E-Cutout After Cats
-Replaced Spark Plugs & Wires
-New A/C Compressor, Accumulator, and Orifice Tube Installed
-Replaced Cabin Filter (Highly Recommended)
-New Interstate Battery
-Fixed ABS Pump
-New Rear Door Hinges
-Spectre Intake W/Black Fiberglass Insulation Wrap
-Replaced Knock Sensors & Harness
-Replaced Intake Gaskets
-Replaced Fuel Pump
-Replaced Water Pump, Thermostat & Overflow Tank
-Replaced Heater Hoses and Radiator Hoses
-Replaced Radiator
Suspension:
-3" Lift Spindles
-New Z71 Rear Coils
-Supreme Suspensions 3" Rear Billet Spacers
-Supreme Suspensions Adjustable Panhard Bar
-JK Rear Sway Bar Extensions
-Cognito Heavy Duty Sway Bar End Link Kit
-Moog Lower Control Arms/Ball Joints
-New Upper Control Arms/Ball Joints
-New Inner/Outer Tie Rods
-Rear Bilstein 5100 Shocks (24-185783)
-Front Bilstein 5100 Shocks (24-186643)
-Front Torsion Bar Lift Keys (cranked about halfway)
Tires/Wheels:
-Wheels - Mayhem Warrior 8015 17x9 Wheels
-Tires - Falken Wildpeak 325/70R17 A/T
-Bluetooth TPMS
-2" Black Anodized Aluminum Rear Hub-Centric Spacers
Appearance/Exterior:
-HD Hood
-HD Grille & Bumper Cap
-Black HD Billet Grille Inserts
-Black HD Bowtie
-Ford Raptor Style AMber LED Grille Lights
-New Windshield
-New Paint Job - 2016 BMW Azurite Black
-New Front Bumper
-Z-71 Front Valance
-Square LED Fog Lights
-Z-71 Roof Rack
-Z-71 Roof Rack LED Reverse Lights - Smoked (comes on w/switch or in reverse)
-Smoked Roof Cab/Running Lights
-Black Plasti-Dipped Wheels
-Black Plasti-Dipped Front & Rear Bumpers and Grill
-OEM Style Fender Flares
-OEM Running Boards
-Black Texas Edition Badges
-Power Side Towing Mirrors W/Smoked Lights
-Spyder Smoked LED Taillights
-Depo Black Projector Headlights
-Black LED Parking Lights
-LED In-Bumper Reveres Lights
-Smoked 3rd Brake Light
-Bully BBS-1212CK Black Billet Aluminum Fuel Door with Lock
-Escalade Appliques
Audio/Video/Interior:
-Escalade Gauge Cluster Swap
-Escalade A/C Knobs
-08-14 Shifter Swap
-3D Molded Dash & Door Kit - Burlwood
-RoadRover Wifi Dash Cam
-Type S Plug and Glow 48" Bluetooth Smart LED Lighting Deluxe Kit
-2004 Center Console swap
-Replaced Driver Seat Bottom foam/Leather
-Metra DP300-2B Double Din Dash
-Joying 7" RK3188 Android Head Unit
-Esky 170° License Plate Frame Mount Rear View Camera
-Full LED Replacement Interior lights
-PLANET AUDIO PL4000.1D Class D Mono Amp
-PLANET AUDIO PL2400.4 2400W 4 Channel Amp
-Front Speakers - Polk Audio DB6501
-Rear Speakers - Polk Audio DB651S
-Downfiring Sealed Third Row Subwoofer Enclosure/Box
-Subwoofers - 2 Pioneer TS-W3003D4 12"
Future Plans:
-4.88 or 5.13 Gears
-Mild Cam Upgrade
-MOVE Replacement Front Bumper
-Avalanche Rear Step Bumper
-NNBS Brake Upgrade
-New Carpet
-Mitt Brown Leather Seats
-etc...
When I Bought Her...
Fosscore
Nice work on the build thread....minus the pics of the mods! :rolleyes:
Austinite
Austinite
Austin, Tx
First things first, I replaced the stock head unit with a Joying 7" RK3188 Android Head Unit. I used the Metra DP300-2B Double Din Dash instead of hacking up the dash. I had to trim it a little on the sides because the Joying is an ISO size headunit. Came out pretty good. I also replaced the Front Speakers with Polk Audio DB6501 components, the Rear Speakers with Polk Audio DB651S coaxials, and added 2 Pioneer TS-W3003D4 12" subs in a front firing box behind the 3rd row. everything was run off a Rockford Fosgate R600X5 5 Channel amp mounted under the 2nd row.
Austinite
Austinite
Austin, Tx
Next step was to replace the old ripped and nasty 15 year old driver's side seat cushion and bottom cover. I didn't take very many pics of the install, but it was one of the best things I did to the Tahoe. Around the same time I went ahead and replaced the gauge cluster bulbs with blue led bulbs. Eventually went with white leds, but never took pics for some reason.
Austinite
Austinite
Austin, Tx
Now on to the suspension round. I ended up going with new Z71 Rear coil springs, Supreme Suspensions 2" Rear Billet Spacers, JK Sway Bar Extensions for the rear, the Cognito Heavy Duty Sway Bar End Link Kit for the front, Rear Bilstein 5100 Shocks (24-185783) & Front Bilstein 5100 Shocks (24-186643), and front Torsion Bar Lift Keys (cranked about halfway). I also replaced the front jounce stops and added 2" bump stops from Amazon for them to rest on. Ended up cutting 1/2" off and installed em on the LCAs. Worked perfectly and rides like a dream now. I went with Pro Comp Xtreme Alloys 1059 17x9 Wheels and Yokohama Geolander A/T-S LT315/70R17 tires.
Austinite
Austinite
Austin, Tx
Next was some generic black nerf bars/side steps that I didn't like too much. I really wanted the oem Z71 steps, but had a hard time finding them and the trim to match. I also found a Z71 roof rack, installed some
Spyder Smoked LED Taillights, Depo Black Projector Headlights, Black LED Parking Lights, LED in-bumper reverse lights, and a Esky 170° License Plate Frame Mount Rear View Camera. I also had a shop install an IMCO muffler and stainless rolled 3.5" tip behind the right rear tire. I can't remember which IMCO model the muffler is, but the total for install and everything was under $200 so I'm happy at the moment. I might eventually go with a louder series Flowmaster, but not positive. The nerf hitch step has been on like 4 of my last trucks, so I just put it on because I had it, doesn't really serve a purpose, but looks kinda cool I guess.
Austinite
Austinite
Austin, Tx
Had to do the fun job of replacing the intake manifold gaskets and knock sensors. That wasn't too bad, but I ended up installing the manifold back on top of the new wiring harness, unbeknownst to me, so after a while it shorted out and the codes came back. I ended up replacing the wring harness and knock sensors again just in case. Cleaned up the intake, the top side of the engine, and the throttle body pretty good while I was in there.
Austinite
Austinite
Austin, Tx
Put on a new-to-me front bumper, bumper pad, a Z71 front valance w/ LED light cubes and Plasti-dipped the old crappy grill.
Austinite
Austinite
Austin, Tx
Finally installed my HD hood, HD Power Side Towing Mirrors W/Smoked Lights, and got it ready to be sent off to the paint shop. I still need to level out the mirrors, I just haven't wanted to jack with it.
Austinite
Austinite
Austin, Tx
Got it back from Econo Paint and Body in Austin, Tx. Only ended up costing about $730 and for the money I think they did a pretty decent job. It's by no means show quality, but it'll do for a $1200 used Tahoe. I went with 2015 BMW Azurite Black, so in certain lights it looks like a midnight blue. I did that because I didn't want to splurge for the extra $400 or so to paint the jams, so it kinda blends. Anything was better than the old ass factory blue, though.
Austinite
Austinite
Austin, Tx
Added some OEM style Fender Flares and Texas Edition Blacked out decals on the sides and tailgate.
Austinite
Austinite
Austin, Tx
Swapped out the old gauge cluster for a Blue Escalade set. Really happy to be able to keep tabs on this old transmission now, plus it churched it up a little.
Austinite
Austinite
Austin, Tx
Removed the Black Billet grill and let the OE HD grill take over for a little while. I think it actually looks better. The billet one might look better if it were the kind that you have to cut out the old grill, but I wasn't going to do that just yet and seeing the grill behind it kinda sucks. I also found some Escalade appliques/vent covers for the rear. They're not an exact paint match, but they'll do for now. Eventually I'm gonna get them and the gas tank door paint matched to the Azurite.
Austinite
Austinite
Austin, Tx
My Rockford Fosgate R600X5 5 Channel Amp took a crap on me just outside the warranty date, but Amazon came thought and gave me like 75% of the original price for it. So instead of going back with a "trusted" brand, I took a chance and went with slightly an off brand set of amps. For the 2 Pioneer TS-W3003D4 12" subs I went with the Planet Audio PL4000.1D Class D Mono Amp and for all the door speakers I went with the Planet Audio PL2400.4 2400W 4 Channel Amp. They both fit perfectly under the 2nd row and I couldn't be happier. I'll eventually upgrade the battery and alternator, but they're working fine right now. Ignore the birds nest wiring, it's a work in progress.
Austinite
Austinite
Austin, Tx
Installed a new ProClip angled phone mount with a WizGear Universal Stick On Magnet. It's angled perfectly and doesn't look all ghetto. The magnet holds the phone on there tight AF. I also installed an in dash USB 3 dual adapter in place of the cigarette lighter hole. I have them both connected to my Joying Android headunit, so I can update my playlists by just plugging in a thumb drive to the dash. Or a passenger can plug their phone in, either way.
1948Buickroadie
