Ok, just adding to my build page:p
Question : Can someone post a pic of how the heater house bracket is mounted on the valve cover. I was able to get one to replace my missing one.
Note: Tires on the rear are just a hair wider then the fronts, 305/45-22's compared to 305/40-22's. I kind of like the look of it.
bottomline2000
Dallas, TX
Ok, just adding to my build page:pView attachment 79408 View attachment 79409 View attachment 79410 View attachment 79411
Question : Can someone post a pic of how the heater house bracket is mounted on the valve cover. I was able to get one to replace my missing one. View attachment 79412
Bracket mounts to a stud between the first 2 coil packs.my bracket looks different.
Ordered AC Delco rear brake backing plates, Wagner rear brake pads & parking brake shoes
I hope you got 2-piece backing plates or else you have to pull the axles to install them. Dorman makes the 2-piece ones that avoid that hassle.
Bowzer
SoCal
Drove it with the new Blackbear tune. Power gains most noticeable in the higher rpm range. Shifts nice and firm and revs a little higher too. Low end throttle response same as before though. Here's a sound clip getting on the freeway:
95escahoe
Nope I got the AC Delco one piece backing plates, read a few reviews about the Dorman ones being thinner and rusting out quicker, I know you gotta pull the axles but I'd rather go through all that and replace them with ones I know that they will last the OEM ones lasted this long, the passenger side one is in pretty good shape the driver one is shot, I'll do axle seals & bearings too
05Single
afraid of the dark
Sittin proper :gr_grin:
How does it ride now with less sidewall?
Now remove the steps and dip the chrome bumper.
Took it for a short ride, I had to use the heat gun on the rear inner fender Wells because the rears are a little wider. Steps are staying! I'm still thinking of doing the chrome bumper. Still not sure if I'm gonna leave the wheels on yet.
05Single
afraid of the dark
Ptm grille then? Lol
Merch619
