LED drl
Crippin87
Crippin87
Oh gotcha yea I would probably just go that route then, the 2 set looks better to me but it's all personal preference lol
95escahoe
Just ordered the 2nd ones had a similar set on my OBS Tahoe
jaywoo65
Cabot, AR
Within the next month or so I'm going with these I think:
http://www.ebay.com/itm/381180235199?_trksid=p2060353.m1438.l2649&ssPageName=STRK:MEBIDX:IT
05Single
afraid of the dark
Na it's still a NBS the Escalade headlights have a plug going to them, so all the pigtails and wiring is inside the light
Thinking about these ones I've had good luck with Depo in the past
LooKS like a black and white pic. Might still have the amber reflector
TheAutumnWind
I have not seen my drls lit up yet. I've got the led drls in place.
the blinkers worked and hyperflashed so I swapped the incandescent lights back in until I got my resistors.
95escahoe
If you have the keyless entry unlock it around dusk or early in the am they should go on then that's how I checked mine on the Silverado
TheAutumnWind
still no LED DRL's on. My bulbs were pretty burnt up wonder if the sockets are burned out.
Might throw a 3157 ive got laying around in one side and see if it works.
If I have to splice in new sockets I may as well do the 4 DRL mod
95escahoe
You can get new AC Delco pigtails on Amazon cheap had to splice in new ones on my Silverado
05Single
afraid of the dark
So you're not even sure if the bulbs turn on?
Hook up a lead to the battery and touch the bulb to it to see if those even light up (I have a loose 3157 base socket with a long lead to test bulbs, easiest way). I've received a pair of bad bulbs before off ebay, rare but it happens. If not contact the seller asap.
Or try putting in regular filament bulbs in the drl spot and see if they come on. If not then check the fuse?
Crippin87
Crippin87
Those look good! I've been slacking, been busy I need to get an updated pic with both the led drls in.
Crippin87
Crippin87
Have you tried pulling the bulb out and rotating it 180 and putting it back in? I had to do that with a few of mine to get the polarity right.
TheAutumnWind
Yeah I did that when I installed them. The 4114's had some visible discoloration and melting going on so I'll bet the sockets are toast. Or I blew a fuse or something.
95escahoe
Amazon has the AC Delco sockets
jarydM
Lost in the Woods
Tennessee
this is the style I want for my Tahoe, I want to order them, and replace all the signal lights with switchbacks, so they function as one solid DRL LED line, unless signal is activated. Hard to find someone thats done that however, and I don't have them in hand, so I can't really imagine how to re-wire the setup.
HiHoeSilver
Away!
Chicago
Damn you twin brother, those are literally the last thing I added to my watch list... Lol! You are always a step ahead of me.
jarydM
Lost in the Woods
Tennessee
Next time I drive through CHI we'll have to meet up and park em for a double take pic! haha
Bob LaFord
