LED Fog light bulbs
osfd442
Long Island, NY
Hope its ok to post this in this category? I have an 08 Tahoe LTZ and I want to replace the fog light bulbs with LED'S, can anyone recommend an LED bulb that is good? Thank you
Fosscore
Honestly I do not run them often. When I have run them, nobody has flashed me.
Further, I did not even bother to go as far as to check the cutoff.
Might give that a go to see what it looks like.
TheAutumnWind
I had flood style led pods in my fogs on denali and used them like offroad lights, never where I expected oncoming traffic. Worked great on the backroads. I am hoping for something that will work in my lade's rectangular fogs and make them actually useful.
njracer
Just ordered the bulbs from Amazon and they will be here on Sunday.
Will give a review once I put them in.
Drok
Cold place in the north
I got some off amazon too(yellow) and they work great, the neg side was they were a pita to install. The o rings were too big.
I forget what kind they were ill try to find the ones and post it.
08HoeCD
Check these out I put in my 13 Suburban.
You can see them, in my build thread here, post #69
http://www.tahoeyukonforum.com/threads/fosscores-2013-suburban-ltz-build-thread.87856/page-7
And the bulbs on Amazon here.
https://www.amazon.com/dp/B01E59I2QA?tag=viglink20600-20
These are now installed in my Tahoe. I doubt you can do better for even three times the price in terms of easy installation, light output, color temperature (white with just the very, very slightest hint of blue) and beam in a stock reflector housing.
Slam dunk.
metelhead
Slam dunk.
Please Tell me these are easier to install than the Headlight bulbs? (those were a pita to replace).
TheAutumnWind
they should be easily accessible from underneath.
They should have designed the nnbs headlights like the nbs ones. Super easy to remove.
08HoeCD
Yeah, easy.
Open wheel well liner, reach in, disengage stock bulb by hand, remove stock bulb, replace with LED bulb, install, fasten wheel well liner.
Maybe 10 minutes per bulb, taking your time.
Vanquish Auto
202 Wallace Ave N Unit 12 Lehigh Acres FL 33971
Pics of said bulbs?
Link to purchase?
This is the new 12000 lumens kit.
njracer
Well, I ordered the fog lights and in just about 1 month one bulb has already burned out.
X-ray Nerd
