TOO LOW FOR DD ??
M
Meccanoble
Georgia
LOL I'm actually planning to put my tires on top of the car, thats how low I want to go lol. Joke but thanks to NORCALL SS and you all, I understand truck suspension much more and importance of bagging. I am leaning to no drop for now and just shocks and sway bar. Assumption that 2" drop in rear alone will be minimal improvement unlike the real drops like 2/3+ that you guys are doing.
Hope this feedback is helping others on the fence about how low they want to go.
Spark it or park it.
M
Meccanoble
Georgia
LOL, I believe yaw but my pockets require Ido this in partition. Aiming for shocks and sway bars. During income tax in a year or 2, i'll do the drop and bags at the same time. I would do it all at once but need to prepare for anything that can come up.
But Ideal setup sounds like 2/3 drop with bags and Bilsteins all over. JDM sway bars seems like the way to go. Cheaper than the rest and great reviews.
inmypassatlife
3/5" drop with 24's on 305/35/r24 plenty of guys like myself use this as our DD and plenty of us also tow. do it right and don't worry about it.
KBones
My DD has 3/5 drop with 26's and I love it. Just get quality parts and your ride won't suffer
M
Meccanoble
Georgia
I have to remember this is a truck not a car that is already kind of low. Helper bags do not make you lose anything like spare tire right?
Nope
KBones
Right. They just sit inside the rear coil springs
robsan1
australia
Thats great to know. One of my biggest concerns with dropping was towing.
The popular shock/springs are the Blistein's. Assuming this combo is what you would recommend. Bags sound expensive. Do they make the ride that much better than aftermarket shocks? How is the longevity?
robsan1
australia
2/4"will be fine thats what my 2010 yukon has i tow a 3 ton travel trailer steep driveways etc drive at angle
okfoz
I always thought that 2WD trucks could pull more because of the weight. 4WD weighs more, therefore the recommended strain on the axle, driveshaft, drive-train, etc. translates that you can pull more with a 2WD because the truck is lighter and it frees up more weight for the trailer.
Apparently I have been thinking wrong.
PR RAY
What size tires are you running on those 26s? I plan on a 2/3 drop on 26s. Trying to decide between 255/30/26 or 295/30/26. Don't want to rub on the windshield washer reservoir.
mizzouguy
Lake of the Ozarks, MO
I DD with a 2/3 drop and have no issues, just have to be a little more mindful of steep driveways and take them at an angle. I also tow a heavy enclosed trailer occasionally and it rides on the bumpstops so I'd suggest helper bags and/or free travel mod.
KBones
My tires are 295/30R26 and the only thing that the tire gets close to is that washer fluid tank. I moved it up a little so I have no issues. I also heated up the plastic fender wells and molded them with a rubber mallet for extra clearance.
KBones
The helper bags ride a little stiff if you're not towing and have more than about 8 lbs of air in them but are still a life saver when you have something heavy behind you.
PR RAY
My tires are 295/35R26 and the only thing that the tire gets close to is that washer fluid tank. I moved it up a little so I have no issues. I also heated up the plastic fender wells and molded them with a rubber mallet for extra clearance.
Thanks KBones. I can't wait to lower mine.
Drewphil
