#1taho
5150TAHO
niagara falls ont
That is a mod for lifted trucks with a crank. You want to keep the jounce bumper in contact with the lca there.
It might be worth taking a look @ your jounce stops though, if those are degraded that would hurt the ride/suspension performance in a similar way.
Mine are due to be changed. Waiting for some better weather. I will be looking into the pucks also
HiHoeSilver
Away!
Chicago
Installed my Airaid Jr.
Also changed the other 3 steering wheel buttons cause a couple lights were out. I had done one before, and the color was just so slightly off from the rest it was driving me nuts. Then I lost two more lights, so.... Now all 4 are new. Those bottom 2 are a PITA.... Snapped the little clip off the harness on first one I tried and chewed the plastic up pretty bad, so it won't 'click' into place. I did get it to seat, and it all works, so here's to hoping it stays that way!
95escahoe
Did you pull the airbag?
HiHoeSilver
Away!
Chicago
I didn't when I changed the first one a few weeks ago. That was one of the top buttons... Super easy. Today I started with a bottom button because that's where the lights were out. After I messed the harness all up, I decided to pull the airbag to see if it would give me more slack. It didn't make a difference. I adjusted my method a bit for the other side and it was no problem. Still pretty tricky, but done quite quickly with no damage.
95escahoe
I didn't even I changed the three first a few weeks ago. That was one of the top buttons... Super easy. Today I started with a bottom button because that's where the lights were out. After I messed the harness all up, I decided to pull the airbag to see if it would give me more slack. It didn't make a difference. I adjusted my method a bit for the other side and it was no problem. Still pretty tricky, but done quite quickly with no damage.
Just curious because I got mine off with the bag on but needed to pull the bag it gave me the lil extra slack I needed
HiHoeSilver
Away!
Chicago
Yeah.. I really feel like you just gotta pull harder than it feels like you should. With the first one tonight, I was afraid to because I had chewed that harness bad enough that I could see the crimp pin on the brown wire and didn't want to pull it out. I pulled the bag so I could put a tiny screwdriver in from the back to support the harness so I could push the button onto it. It sucked. If it was something with a significant draw I wouldn't leave it, but its all working so I figure the worst that can happen is it will find its way back out and stop working.
:emotions122:
Fosscore
Yep PITA. I pulled my airbag and ended up using fishing line and a lot of firm pressure to get that harness and button matched up.
Nice work.
HiHoeSilver
Away!
Chicago
Nice work.
I tried the fishing line trick first, but I just couldn't get it lined up. That's when I went to the needle nose. Repeated grabs are what did the damage. On the next one I got a good grab, gritted my teeth, and PULLED. Lined it up and, 'click ' good to go.
Fosscore
lol I used all those same tricks as well. Needle nose tugging the cable, line, lots of colorful language. :eek:
Can't you pull the steering wheel to get to them easy like I did on my 02?
ATIII
Brighton, CO (Denver)
Exactly my thoughts. Just yank the wheel off. It comes off in 2 mins and then you can work the harness without the rear shroud on it and its cake! Anybody nervous about the air bag, don't be, just push a pick into the holes and it releases really easy, set it aside and your done with it, til you wanna re-install it, then just click it in like your honking the horn. I've had mine off a few time now and have a different wheel too.
Just make sure to disconnect the battery first so there's no surprises lol. I borrowed the puller from my local auto parts.
05Single
afraid of the dark
When I do mine I plan to just drill a hole on the back side , push it in from the rear. Then find universal colormatched plugs and pop them in. Nobody would even notice
Fosscore
Yes you guys are correct with the battery disconnect and the steering wheel removal. I just did not take that step in the process and it probably would helped a bit more.
HiHoeSilver
Away!
Chicago
Hmmm...
This is essentially what I ended up doing, only you don't need to drill. Once the bag is off, you can get a little screwdriver in from the back by coming through the same slot as the wiring.
dizhai
