95escahoe
Took it out for a spin in the snow today
Lol get that 4wd working you'll need it living up this way
We'll, I've had the Hoe since late 2012 and I've only had to use the 4wd less then a handful of times. Just gotta know how to drive in bad weather. Born and raised in Jersey, so I'm used to the snow.
massivespl
I'm not mean, I'm honest.
Michigan
True that. And a good set of tires.
Yup! Trick turbo kit with a 76mm magnum. 60# deatschwerks fuel injectors, Walbro gss 340 fuel pump. Only thing missing at this point is a catch can and a tune.
Sweet. I have a Whipple on order and have everything else on hand now that I got my gauge pod today. I just colormatched it so it's ready to go. Test fit with my AEM Wideband Failsafe AFR / boost gauge.
a4edwin
ny
What did you use to color match the pod? I got the overhead billet one but won't be able to use it. I have the auto climate and when I disconnect it I loose all function from my rear a/c
I used SEM adhesion promoter and Spectra Match paint that I had left over from some other interior project. I ran out of my SEM interior paint but the Spectra Match is dead on as well.
osiris94ej
Casper Wyoming
After owning this thing for almost 6 year's I finally dug into this and figured out the hack job wiring. Every wire was blue past the headliner. Took it down and cleaned up the wiring disaster. Still can't figure out the dome light and I lost patience with it.
Sent from my SM-N920V using Tapatalk
Mountain Rambler
