05Single
afraid of the dark
Well I just looked up my insurance card and State Farm lists mine as a "Sport Wagon" SMH!
:supergay:
MadDogDelpho
Texcellent
I think some parts got updated numbers over the years, even if the part didn't change, because of GM in their "infinite wisdom"
TheAutumnWind
Installed a new front grille today...light bar in the grille isn't permanent, still undecided what I'm doing. Blinkers also need to be sealed better, they're full of moisture:(
you blacked out those cross bars for the core support! Nicely done. That is something that most people neglect with an open grille like that and it sticks out like a sore thumb
I'd love the punisher decal if it was silver or black or something. Just slightly more subtle. That's just me tho. Still a fan. Looks awesome.
I like everything in silver or black though so maybe thats not surprising.
Looks good. I like the grill. I sealed all my after market lenses with a bead of clear silicone. They ALL leak. Take the ones with moisture out and take as much of the moisture out that you can-rag, tissue etc, then hit them with a hair dryer. That'll get them nice n dry, especially those led parking lights. I cracked open a set of those, pulled those leds out and there was rust in there. Def don't need that. Since I ran the bead of silicone, no more issues. Forgot-- maybe run a thin bead on the bulb receptacles, where they screw into the back of the lenses, the aftermarket don't fit snug enough and they could still let moisture in.
Cattivo
The Concrete Jungle
Thanks, I color matched all the cross bars behind the grille to help blend everything in
I made the punisher decal myself and decided to paint it red for a little contrast. The whole murdered out look is cool and all but I don't want to look like every other car/truck on the road
I'm sure you can get a black or silver punisher online
Cattivo
The Concrete Jungle
Thanks, I bought some black silicone last night since I'm gonna need to seal the roof after removing the rack...I'll try and seal the perimeter of the lenses after I remove all the water. Did you remove the 2 breather hoses or just seal them up on yours?
I left the breathers in, figured it couldn't hurt. I took my rack off and just put the bolts back in the holes without silicone and it's been fine. Been off over a yr. Skip the silicone. The nuts for the rack are welded in, sort of.
Fosscore
Well since he already had one set up the way I wanted, it's done. Quick drop n swap. Going to pick her up in a few hours. Details to come......
Damn man...that might be the quickest transmission swap ever. Hope it puts you back in business better than before.
wwiizz
