What oil filter do you use?
PG01
Up here to the right
Just want to see what everyone uses...
A/c delco
Fram
K&n
Hmmm maybe i should have created a poll? I saw that option right before i posted oh well shit happens
AppocAlexx
Darth Appocalexx
Abilene TX
Ever since working at pep boys some years back I have seen to purchase Purolator Pure Ones and if its not too much of a difference or on sale get the Boss now.
drakon543
I went through an article a while back about oil filters brand vs brand. I cant recall the mag i found it in but it was a good read with some legitimate numbers and testing done. Unless its some crap no name brand filter they are pretty much all the same. I do remember i think fram was 99.98~ or something like that and a k&n filter was a little better but such a small amount i just stopped buying the more expensive filters. The only reason i buy the Purolator one filter is the grip paint they put on them. That and advance around here atleast stopped selling fram filters.
NGAneer
NWGA
Look around the web and you'll find articles where they've cut open filters to check the internals and filter media. For my money I go with...
1) Mobil 1
2) Purolator Boss
3) Purolator One
4) Wix
The Purolator One was my default before they came out with the Boss. Boss is just a step finer in media as far as I know and the Mobil 1 was just about as fine as you could get a year or so ago.
Plimbob
Des Moines Iowa
I noticed that when I use Purolater One I have less lifter clatter in a cold start (midwest winters). I drive a good amount of highway and the oil seems fairly clean after 2,500 miles as well.
However, I haven't tried Mobil 1, K&N or Boss. I have used AC Delco and it seemed OK. In one of the kids vehicles - 2000 Jeep Cherokee Classic with the inline 6 I used Wix because it seemed to be better at holding oil pressure on start.
AppocAlexx
Darth Appocalexx
Abilene TX
working at a parts store and if you actually care about the parts you sell then reading up on them is a think you should do. At least I did. It felt better pushing stuff to sell that I actually knew about. I read same kinds of articles basically for all brands. Not much of a difference as long as you stay in the higher grade of w/e manufacture you like. I have always stayed away from Fram mainly due to a couple race cars from my dads friends were using their high dollar filters at the time (2005ish) and the filters inside the canister started breaking apart and oil pressure lost and things went bad. These two cars happened within the same summer. These cars were street dragsters and did oil changes after each weekend sometimes after a few races depending on that day. Maybe they got some bad apples but ever since then I have never and will never buy Fram.
drakon543
Probably either bad apples or some odd ball occurance. Matters not prices aren't really any different and for regular dd n/a engine any notable brand filter would be fine. Used only fram for a while never had a problem but i used to use bosch spark plugs for a long time aswell. Had the bottom of one of those come off a while back been using ngk since.
Kenny D
Crosby, Tx
Being I just bought my 09 Tahoe, I used AC Delco on my first oil change. Not knowing what oil was already in there, I used Castrol High Mileage Synthetic blend oil. Next change I will go with full synthetic.
spyboy49
Purolator One and synthetic oil. I've used them on my '04 Yukon, '06 Buick Lucerne CSX (BIG Northstar V-8), and before it was totaled, my 2001 Chrysler 300M. I would go anywhere between 5K - 6K miles between changes. Never had an issue and the oil looked pretty good at the changes. There was some research and testing on filters a few years ago and if I recall correctly, Purolator One, Mobil One, K&N, and Wix came out on top. Used a Fram (it was free) on my mom's Mazda and it leaked after 1K miles. That was the last time I used "agent orange".
NGAneer
NWGA
Last time I used a fram filter it blew the seal on startup and sprayed oil all over the garage floor. Sounded like a garden hose.
BeenChevy
Minnesota
Mobil 1 M1-107 Extended Performance Oil Filter:
  • Provides long-life performance for today's longer drain intervals
  • Effectively removes contaminants, with a 99.6 percentage Multi-Pass Efficiency Rating and an advanced synthetic fiber blend media
  • Holds double the contaminants compared to other filters, with 28.0 grams of total capacity
  • Withstands nine times normal system operating pressure, for exceptional protection up to 615 pascals per square inch
  • Prevents dry starts by eliminating internal leakage during shutdown through the use of a silicone anti-drain back valve (where required by OEM)
Mobil 1 5W-30 High Mileage Full Synthetic Motor Oil
inmypassatlife
Supertech Oil filter thats made by Wix now and Supertech Oil dino and syn, made by warren oil. I am a bitog fan
Miami-Dade
Moderator Supporting Member
AC Delco..Plan on switching to Mobil 1 next oil change.
Conedaddy
