35 inch tires on leveling kit
bryanfrags
I just recently put in a readylift leveling kit. Raised my truck from 36 inches from the top of my wheel well. To the ground. And now its 39 inches all four wheel wells. At full wheel lock with the stock 31 inch tires I have like 2 1/2 inches of clearance between my wheel and the wheel well. I am wanting to put 35 inch tires on. Has anyone else fit 35s with just a leveling kit?
01Konvict
Boats n Hoes
Raleigh/SML
Yes you can stuff 35s but avoid a 12.50 width, you will need to stay narrow around 275/65R20 size. Any suspension travel will rub places, best to do a 33 on key lift max of 34
the04project
I agree with 01Konvict im running 33.8x12 and I am very close to scubbing even though I have not had to trim any and rub every once in a while at full turn reverse at an angle.
Red_Raider
Derby, Kansas
Stay away from 35/12.5/20. You'll have to do lots of trimming! 33/12.5/20 work great now though I did like the look of the wheel well being stuffed.
the04project
I talked to my tire guy the other day because I was thinking of doing the same and he said he has put a set of 315/75r16s on one with 3 inch keys which is a 35 just not as wide but he also said to clear them they had to crank the key all the way up which will ride rough and is bad on your cv joints and he's been in the business for 20 years or more so I trust him
jough
Arkansas
I raised my front end 2-2.5" and have 285 70 17 Nittos on factory 7.5" wide wheels.
The biggest tire I could run with this set up would be a 295 70 17.
I'm already close to cladding contact in front and have a very slight rub on DS rear whee lwell liner. If I were to go bigger, I'd need to crank the keys a little and get wheels with less offset.
bryanfrags
bryanfrags
I decide to go with 285/75/16 federal couragia m/ts. I have seen many people with that size tire like the look.
---------- Post added at 01:52 PM ---------- Previous post was at 01:50 PM ----------
I have decided to go with 285/75/16 federal couragia m/t. I have seen many people with that tire size and I perfer it over that stuffed look like what Red_Raider said.
hoe
I have tremendous trimming done to fit 35x12.5x20s! And I'm on a full suspension lift of 4" right now. Tires are so wide I had to space them away from the truck 1" as well. As they had touch the frame in the back.
The trimming consisted of all the hard metal behind the inner wheel well lining and fender. Got nice clearance now!
To fit 35s I would recommend 4" or better!
cbepro
I had 315/70/17 on 9 inch wide rim with keys and 1.5" spacers. I actually had those tires installed with stock keys. Just had to trim where it rubbed in the front bumper and fenders. It wasn't anything major, like making 33's fit on a XJ with no lift. Never rubbed since adding the keys. I also never went offroading so can't comment on that aspect.
Yes, 315's aren't true 35's. But with trimming i don't see why 35's wouldn't fit.
There's also this option for trimming: http://www.duramaxforum.com/forum/n...1-nbs-hd-large-fender-mod-step-step-pics.html
upton4x4
Does anyone know of any suspension lift kits that are less than 6"
Flexx
I'm rolling 35/12.5/17 on keys and spacers. Did have to trim a bit and shave a bit. But doesn't rub unless I'm full lock flexed. And looks awesome. 100x better than the 285/70/17.
Sent from my HTC One M9 using Tapatalk
Carbonbowhunter
What kind of trimming do you have to do? I'm getting a 3" level kit this weekend and want to go with 35x12.50
Flexx
Cut front bumper, trimmed inner fender liner, push back z71 cladding, and still rub a bit in full lock. And I'm running close to stock offset. Any more and no way could I do it. A non z71 will have more clearance.
Carbonbowhunter
Mines non z71 so hopefully will fit I'm gonna try to get as close to stock offset as possible but closest I can find is - 13mm for the 22" rims I want... I know I know they won't look quite right, but... They will look better with the 37s I wanna put on them later this year when I get the 8" lift
Flexx
-13 you better run 33" tires.
Carbonbowhunter
Thanks for the info! I'm sure I'll be hitting you up to pick your brain again soon.
Jonesy92
Port Clinton, Ohio
Definitely love Al the input.
Currently installing a 1-3” leveling kit on my 03, while painting and prepping my 20’s for final paint, and clear. I wonder how much I can trim being as I have the non-xl version, and I have but maybe an inch where the rear doors close into the body..
curbud
