NORCAL SS 1-2.5/3.5-4.5 2wd/4wd kit.
2016YUKONSLT
Do you have anything that doesn't require cutting, just in case I decide in the future to jack it up 6" and put some swampers on it? Just in case I find a large puddle at the local shopping center...lol
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
swaybar brackets you can put into the stock holes which is cake.
in rear if you go not the full drop you dont have to cut bracket off frame
any mods you do with lowering will not change anything when lifting in rear. You can put a 6" kit no issues if you decide lowering is not what you wanted
2016YUKONSLT
So the bracket that you cut off is just the bump stop bracket? It isn't for anything else? Do you have an install video?
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Google Tahoe free travel mod all you do is cut that bracket. with my kit I then include new bumps tops that bolt thru existing holes already in axle pad so you don't bottom out.
You get tons more travel doing this
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Nope. I will have the first belltexh batch probably late jan
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
I have milled the older spindles and they fit. I sent info to belltech and told them what needs to be done.
lynxnova
New Jersey
Thats great news but I thought belltech already had new ones in production coming any day now.... or are they just gonna remilled all the old ones from the last model .
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
The test model didn't go as okanned. I'm hoping they can work off info I gave em
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
I showed them how to mod the older spindles to make work. So just waiting to hear back from them
lynxnova
New Jersey
Ok, please keep me informed. I'm desperately waiting and wanting to lower this Tahoe already....
gat0r
DFW
^ a few of us are interested in these ;)
tony
have they given any hint @ pricing yet?
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
mcgauhys not making them for at least another year. At sema they said it wont be out for a long time
Auto Skins llc
How do these drop kits handle with towing trailers and larger boats?
Looking into a 2/4 drop for my 07' 4wd suburban.
BluVelvet2xHo
Omaha, NE
Could you put together a kit that would end up 2-4/4.5-6? Say using McGaughy's drop spindle AND strut cup for front and your custom rear spring with spacer for the rear? I'd like to start with 2/4.5 but have the flexibility to add the cup in front & remove the spacer in back for more drop. I'm only going with 22" wheels since this is the wife's daily driver. Would this combo accomplish what I'm thinking?
Durobans
