Rough idle only in cold weather? Please help
edd112
My 04 Tahoe has a weird idle when I start it, only happens in cold weather! Never have this problem during the summer months. Once the truck warms up it runs fine, most videos of "rough idling" cars are way different than this. Sometimes it will drop to 500 rpm or lower and feels like it will turn off. Also it's throwing a random misfire code
I have replaced
Fuel pump
Crank position sensor
O2 sensor
Full tune up
Cleaned all fuel lines
Fuel filter
Cleaned MAF
I hope it's not intake gaskets, I've taken very good care of this truck, has 130xxx miles. What could be the problem
Larryjb
I've had the same thing going on my 02. I put a scantool on it and narrowed it to cylinders 3 and 4. Because the plugs and wires are quite old (perhaps original... I got it used last summer), I'm going to replace with iridium plugs and new wires. If I still get a misfire on 3 and 4, I'll look at coils next.
I would think that a leaking intake gasket wouldn't improve so dramatically with a temperature change. When I saw how the nylon gaskets failed in my 3.8L, chunks of the nylon would give away leaving the rubberized part of the gasket with no support. I don't see a cold/warm engine improving this so dramatically. I could be wrong, though. I've been wrong before.
Larry
edd112
edd112
Larry[/QUOTE
Yeah it never does this during the summer months. I've had this truck for 2 years and it always has this problem when it's cold outside. It runs like a beast when it warms up though since it has a fresh tune up and clean fuel lines. Always changed oil on time.
I should add that I installed a k&n air filter. Although I doubt that is the problem. My brother has had the same filter on his 04 Silverado and has never had an issue
#1taho
5150TAHO
niagara falls ont
Try spraying air intake cleaner around the intake and see if the idol changes. That will tell you if you have a leak.
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
Also check intake tube. If there is a leak getting by the maf.
Larryjb
See if you can borrow a scantool and check the misfire history. If you have misfires on just one or two cylinders, that will help narrow down the issue.
I did have a MAF go bad on me once, but it caused the engine to just quit.
I would expect any intake leaks to cause random misfires among all cylinders.
If you have a random misfire on 1 or 2 cylinders, try swapping coils and see if the misfire moves to the new cylinder with the coil.
Also, don't expect new plugs/wires/coils to be problem free. I've been caught on that more than once.
Larry
edd112
edd112
Larry
Still misfires randomly, next thing I'll do is test the MAF
bottomline2000
Dallas, TX
Intake gasket...mine went bad when my motor was stock. Sounded like it was cammed.. the cold weather makes the gasket hard enough to create the gap. It would get better as the engine warmed up and eventually run normal. Cold start and repeat..metal fel pro intake gasket is your friend..
Sent from my SAMSUNG-SM-G900A using Tapatalk
95escahoe
X2 on this had the same issue
Larryjb
Just to update you on my Tahoe, which also has a bad misfire on a cold engine. I just changed plugs and wires, and moved a coil from cylinder 4 to 2 (I have a bad misfire on cylinders 3 and 4. ) l still have a bad misfire on cylinders 3 and 4. I am also getting a lean condition code on both sides. I now suspect it's the intake manifold for me. I guess temperature really can affect it that much.
Larry
Larryjb
Further update: did the intake manifold gasket today. I didn't have time to do the knock sensors, but I did look at the rear one and it was dry and still shiny. I'll see about doing them in the summer, maybe.
My rough cold idle is solved. I could get no confirmation of a leak using the carb cleaner trick. Don't take a negative result from a carb test to mean the intake gaskets are good. They may still be bad.
Larry
Larryjb
bottomline, I used the Felpro metal framed gasket also. I don't think it's so critical on our intakes, but I know they're good. The metal intakes were critical to use on the GM 3.8 which had coolant passages. Hot coolant that has gone acidic would eat through the nylon gaskets like a rat. And that early Dexcool, at least, wasn't so long life as they would have hoped.
I gave it a good test run tonight. Nice smooth idle. I saw LOTs of leakage through cylinder #2, exactly where I was getting misses.
By the way, lots of people say to dispense with those sponge things under the intake. I can vouch for the fact that those sponges actually did keep things a little cleaner in there. I didn't do the GM TSB regarding the RTV sealant around the knock sensors. I also noticed a lot of dirt/oil/soot buildup along the top back of the engine. It didn't seem fresh wet, so I can't prove or disprove my oil leak source from there. I do have a replacement oil switch too, but it was getting cold and dark so I skipped those steps today.
bottomline2000
Dallas, TX
Yeah I don't think the felpro is critical but it is more robust than the plastic framed gasket.
I thought about leaving those foam guards out as well. Hindsight is always 20/20..
Larryjb
The foam guards may have actually worked as intended in my Tahoe. As I said, that rear knock sensor was in perfect shape. There was a little debris in there, and some soot buildup, but it was a lot less than on the outside of the foam guard. I thought about removing them, especially the rear one as recommended by the TSM, but when I saw how much soot there was on the block just outside the foam insert, and how little there was inside, I left it in for now.
I do have an oil leak somewhere. It could be near the top end, but I do think my oil adapter gasket needs changing as I think that may be the majority of my leak at the moment. I'll do that at the next oil change I think.
Larry
mattt
I believe my 5.3 needs intake gaskets as well. Any trip to cold temp areas and I get P0171 & P0174 (Lean both banks).
My engine is exactly as you described on top -valve covers, intake, etc
""I also noticed a lot of dirt/oil/soot buildup along the top back of the engine. It didn't seem fresh wet, so I can't prove or disprove my oil leak source from there.""
Oil leak from where would cause that dirt/dried oil/soot buildup?
Would you mind sharing the TSB you are referencing as I am going to do intake gaskets soon.
mattt
Thank you! Looks like the TSB won't apply to me since I'm in an '04. Thanks again.
Now if I could locate the source of the dirty top side, have the dirty bottom side too, but it's wet and drippy down there....I'm thinking rear cover and/or oil pan.
rockola1971
Indiana (formerly IL)
Check your oil cooler lines.
Hodmjstone
