Did I crank my t bars to much? Post fender heights please
tahoe035.3
I have ford keys in the front the driver side has about 1/2 inch of bolt left and the passenger side has about 1 inch or more sticking out I have 33in tall tires and my fender height is 39.5 in the front and 39 in the back all I have in the back are z71 replacement springs and I seen someone had cranked to much on here and his a arms were hiting the droopstops and his fender heights were only 38/1/2 or something like that. I don't have my droop stops anymore and have limiting straps instead, all the ballpoint angles look fine I was just wondering if anyone else's thinks I cranked my t-bars to much I uploaded a picture of how it's sits now I'm just curious to what anyone else thinks
Fosscore
Color match always a win. Worth the wait. I've been without my hood for 1 month, with the holidays, so I know the feeling. :)
T
tahoe035.3
Yes it is. I did the grille and back bumper myself but I didn't have enough time to get the front bumper in before I went back to work, so I had to bite the bullet and take it to a shop while I'm away from home
Big Mama
Virginia
Is there any particular problem you're having or are you just wondering why you have more bolt exposed on one side than the other? Does your alignment feel ok? Are you experiencing any mechanical issues as you drive it or is it just a matter of the other guy's fender height was different than yours. I, like Foscsore can't help with fender height as I'm lowered front and back.
T
tahoe035.3
Everything feels fine to me, I was just wondering why the other guys is lower than mine and he's having problems and I'm not and was just trying to see if anyone thought that maybe I cranked mine to much just curious really
T
tahoe035.3
Take a picture of your angles and post them up. Agree with @Fosscore , your Tahoe looks mean! @tahoe035.3
I will, lol it'll probably be awhile untill I'm able to I'm off working and won't be home for another month or so and thanks man its nice to get compliments on this thing it hardly ever sees the daylight it sits in the garage while I'm gone.
Flexx
Mine was at 39.5" all around on 295/70/17. Zero issues. I'm running 35" now and sits at 41". You're truck looks mean how it is!
Sent from my HTC One M9 using Tapatalk
T
tahoe035.3
Well this makes me feel better we were pretty much at the same height
pt1965
columbia,sc
MY DRIVERS SIDE IS CRANKED AS FAR AS IT CAN GO TO CORRECT A 1 INCH SAG ON THAT SIDE. RIDES BETTER NOW.
Big Mama
Virginia
Something to consider that I didn't see mentioned was the tire size of the guy you're comparing yours to. Does he have the same size you do? If not, it may be as simple as that for the difference in height. If you're not having any mechanical issues and your angles look good just chalk it up to different truck, different results. One thing you can do it take it to either a 4WD specialty shop for a once over or where I live we have an automotive spring works shop that's cheaper and suspension is all they do. They installed my rear springs and front spindles because I didn't want to mess up the auto leveling air springs.
AppocAlexx
Darth Appocalexx
Abilene TX
Iv always been told to never crank your torsion bars as far as the keys can go. That's why they make keys with extra steps in them to be able to go further than stock. Also like the above post said different vehicles have different set ups. Unless you two have the exact same set up on the same vehicle around the same years then you really cant compare as much.
Also not to sound like an ass but do you know how the torsion system works on these trucks? I ask that only bc it will help you understand the amount of stress that the keys and bars are under when you crank them things too far. When you add new bigger keys to old bars your are essentially adding more stress to them. When you replace all components along with brackets they make up the different in pressure and stress of the bars to extending and lowering the whole system.
6point2lovelifers
