Denali Headlight Issues
Davidb5303
On another note, I'm glad you figured this t. It was a real mystery to me why a stock Denali projector wasn't bright.
It does make sense...the reflective material being lifted and cracked would be like a broken mirror.
One other thing you could try is to get a set from a wrecking yard that have yellowed lenses since they would be real cheap, and steal the projector parts. It's not common for them to be peeled like that so you'd probably be good to go. You could take a screwdriver along to check them.
DDenali
Orangeburg, SC
No pictures...figured that was the problem so just put back together and reinstalled....so i guess the next thing it to order a set of black ones and replace Thanks
No problem bud glad you figured it out sorry I couldn't be more help
Sent from Dugar's iPhone 7 Plus using Tapatalk
DDenali
Orangeburg, SC
That's a good solution
TheAutumnWind
Yeah mine are pretty mediocre even with HIR's in em so I am not terribly surprised.
Davidb5303
Put a new set of Spyder ones in....problem solved. So they are no cracks and no yellowing in the original Denali ones, are they worth listing for someone else to convert? just wondering
DDenali
Orangeburg, SC
Glad you can see now bud
Yep. Just make sure to disclose the reflectors. Someone will do a full retrofit and won't need them. The reflectors that is.
jackal78
