05alive
Masshole
I had to go to work at 2 AM today and noticed some de-icer had been applied to the road and there was a bit of icy sheen. I looked at my mirror display to check the temp and saw it was 35 degrees, but then it said "Ice" and went back to temp. It did this a few times then stopped and just displayed temp and there was no more ice on the road. I had no idea my Denali had this feature! I assume it used a combo of temp and traction control to diagnose the condition.
Afaik it's just a temp thing. Mine will do it when I fire it up and it's sitting in the driveway. Close to 32 there could possibly still be ice, so it flashes the warning.
Interesting to me is it only showed it when there was ice even though the temp was 35, and down the road it was still 35 but the ice wasn't on the road anymore and it stopped the warning. Also strange is I've never seen it although I'm always checking the temp especially when it's cold. Maybe I'm just not that observant after all.
MadDogDelpho
Texcellent
Bypass as in you rewired all that back together?
No, I threw in a jump seat from the nnbs trucks and i had no place to put the controls so it was just sitting in the floorboard. I wired the rear negative input to the positive output and vice versa for both sides in the wiring harness itself. not too difficult, just a matter of trial and error. I tucked the rest of the harness up in the dash and called it a day.
Smoke Em All
Taylor,Texas
Do you have a pic of the jump seat?
Knope
NC
I finally got around to replacing the stock sub. Got a pioneer 8" shallow-mount and it sounds great...when it isn't skipping. I had to have a new amp installed since the Bose system was bypassed with the new head unit, so I'm hoping that's not the source of the problem. Back to the shop in the AM :(
Patriot17763
Well they are mounted and balanced and my keys and spacers came in today with all of my LEDs new truck tomorrow morning when I'm done installing everything. I'll post updates
Fosscore
@Knope
Model number or link to sub?
Thx man.
DDenali
Orangeburg, SC
Nice. Maybe you can adhesive that strip on the metal will so it shines down, lighting the board itself, and the strip won't be so visible once it's off.
That's the route I'm gonna take I want the steps to be lite and I guess the area around the steps will be lite as well
DDenali
Orangeburg, SC
Just started snowing in Portland and decided to get a candid photo. If it keeps snowing overnight I'll take her out to play tomorrow.
Ok ok them turn signal lights tho lol bright I love em what did you use
Hodmjstone
