Snow Driving
ISU-152
Haha and im sure its not on point! :challenge:
DWTahoe
Colorado
Awd and 4hi are the same thing, just awd's have no option for 2wd. Auto is when the truck monitor's wheel slippage and engages 4x4 when its needed
ever noticed how the gear selector
Can be easily be pushed into neutral? that is designed for driving on ice. In the event your wheels are locked up on ice, use the neutral bump to cut power to the wheels and lightly pump the breaks.
Ummmm.....I hope you're kidding. For those that are actually new to driving in ice please do the rest of us a favor and never drop the truck into neutral when it's slick out. I'm pretty sure that's not what neutral is for. ;-)
If it's so slick that being in gear causes you to slide you have a lot worse problems. However, you need to be bumping the gas and get the tires moving, then pray that you can actually steer your way through whatever may be happening. Pumping the brakes in neutral isn't going to stop you if it's that slick out, all you've done is take away any control you might have had when the tires stop sliding.
YukonandtheHOE
Ive been in many situations where bumping it into neutral worked good.. that being said alot of people dont have winter for 8 months out of the year and ice roads to access rural communities..
Maybe in city driving its not practical, but for this hick thats my story and im stickin to it :cheers:
cbuckeye20
This was my first year in the snow with the Tahoe. Previous vehicles Mustang, Escape, Fusion (well still Fusion) (and sorry, wife's dad works for Ford.. but I hate the Expedition looks and risked war buying Chevy) basically nothing this high up from the ground
Anywho, we were in that big storm last weekend up in Michigan and I was blinded by my lights hitting all the snow flurries. I'm not sure if I just havent driven in a blizzard that bad or it really is the height of the vehicle which causes the lights to shine on a greater amount of snow flurries, but I never remember feeling so blind before. It just didnt feel safe driving over 20 on the highway when I couldnt see but a few yards ahead
Do any of you drive with foglights only in those kinda conditions? My LT doesnt have any or I would have tried myself..
ISU-152
I've driven in a few blizzards and lights or just fog lights...it's still a blizzard and you can't see. Best to wait it out somewhere, off the highway
Fifty
Yeah. If you're at the point where you don't feel safe driving "over 20" on the freeway, you need to get off the roads and wait it out.
You are an accident waiting to happen. People do that all the time here in heavy rains or fog and usually end up getting nailed from behind or causing someone to swerve and hit some other car or go off the road.
(Retired LEO)
Yukon2000xl
I live north of Montreal Canada and we presently are in a snow storm.Ive spent 24+ years driving in heavy snow and black ice on highways,country roads and normal roads.A few things to remember 1: have excellent tires ,I run BF K/O 2's .2: keep your distance 3: stay off the brakes as much as you can4:don't over steer to correct a slide and you will know why once you grab ashphalt again. 5: remember I vehicles weight can be it's greatest friend or enemy in a snowstorm.
zambonidriver
Having driven a bunch of cars and trucks with snow tires I can say I'm not impressed with the 22/alenza combo. Driving through the snow storm in Michigan yesterday on the highways was not fun. I'm going to snow tires.
As someone said, tires are the only thing that matters. I've driven rear wheel drive sports cars with snow tires that were better in the snow than my Yukon xl with these tires.
Sent from my SM-N920V using Tapatalk
ISU-152
Lol @zambonidriver ....this must be a joke
ISU-152
But more super Canadian tips...
Signal early so the people behind you know what's going on
Brake early...even if it's to warn the guy behind you
WillCO
Castle Rock, Colorado
Good advice here. One thing that hasn't been said yet - it helps to moderate your speed in the snow by gearing down, versus hitting the brakes.
Obviously if you need to stop, you need to stop. Hit the brake. But if you are just trying to slow down or keep from going faster, using the transmission as a brake is effective. The brakes are friction devices whose ultimate goal is to lock up the wheels, except the vehicle's momentum keeps them from actually doing that up to the point where it doesn't. The transmission on the other hand is not trying to forestall the rotation of the wheels and can be used to safely slow you down with minimal risk that you lose traction. This is doubly true if you are moving downhill.
WillCO
I'll vouch. I had a RWD V8 BMW 5 series around here for several winters. I had a set of snows on it, and with the exception of starting from a stop moving up a hill, it was notably more stable in the snow than any of my AWD/4WD vehicles with all-season tires.
Sparky_69
New Mexico
Educate me, what's the difference between switching to AWD vs 4HI? I don't tow anything but why would I use one over the other? I'm coming from a 2002 Denali which is AWD, no option to switch out of that so this is new to me.
AWD has a third differential inside the transfer case, to allow RPM difference between the front and rear driveshafts, that's how it is able to drive on dry pavement without damage.
4WD does not have a differential inside the transfer case, so the front and rear driveshafts are turning at the same RPM. 4WD should only be used when driving straight or when driving conditions are slippery, that's why it can be turned on and off.
cardude2000
A downshift and gently applied brake pressure are identical to the physics at play. BUT, downshifts have fewer safety guards built in should traction be lost.
If you are, say, going downhill and you want to slowdown in very icy/snowy conditions braking has two advantages
1) you can IMMEDIATELY take your foot off the brake if even a light touch locks them up 2) IF the brakes lockup they are IMMEDIATELY mitigated via ABS
Slowing/braking via transmission is problematic because when you downshift your wheels could IMMEDIATELY start sliding/skidding if they don't have traction (trans wants tires to go slower and truck is moving faster. traction isn't enough for tires to bite and slow vehicle). If that happens you cannot upshift immediately meaning you better pray you don't get sideways (which, if you had braked ABD and ESP would work on for you) while you shift and wait for the the tranny to decide when it's going to move into the higher gear (even in manual mode trans shifts aren't instant).
Just my .02 but in icy conditions you are really risking an issue by throwing tranny into a lower gear. I'll test brakes and gently apply much more control IMO. Plenty of traction? I'm right there with you, throw trans into the next gear down to keep speed from creeping back up.
varminpoolteam
