Who else has these bumps on their rear bumper?
Illnasty
New Jersey
So I've noticed this before but finally got some good pics of the bumps right behind the rear tires. I stopped by at the dealership and the tech said those are the mounting points for the bumper. I clearly see three bumps on the drivers side but just one on the passenger side. The tech said he will need to speak to his manager and can't make a determination on what they will do. I 100% do not want it to be sanded/painted. He said they might try to hit it with a heat gun and see if they smooth out. In my opinion, that's ok but if it doesn't work, the entire bumper cover should be replaced. I have to bring it in on 12/14 for an oil change and the recall and will see what they say/do then. The truck has less than 5k on it and is 6 months old.
Anyone else have this issue? What'd you do?
Also just hit the curb and scratched one of the 22's....mother €%#~*+
chicagofan00
Arizona
I don't notice anything like that on either side of the rear bumper on my Tahoe.
Carpenter2361
I would be all over the dealership who sold you that truck.
kurtis5791
I don't have any bumps on my bumper. However I'm responding to your post about your wheel. My wife also hit the curb but she denies it to this day. Just take it to a wheel shop and they will buff it out. Good luck with your bumper.
Tonka Boater
Wayzata, MN
I don't have any bumps on either side. I would definitely have them replace the bumper if the heat gun doesn't work.
Illnasty
Illnasty
New Jersey
Yep, that's what I'm going to tell them. In actuality, it's not a problem with the paint but the plastic bumper so defly no sanding or re painting. I had the interior plastic on my 2002 get stress marks (not sure what it's really called but if you bend plastic the color changes) and they replaced that once upon a time.
itried
No bumps on our 2016 LTZ. Good luck, hopefully they take care of you.
Illnasty
Illnasty
New Jersey
I'm at the shop now. They said they'll take a look but one of the guys said in order to fix, they'll have to order a bumper cover but it will only be primed NOT factory painted and it will involve body work. He also said then I might have an issue with it matching the original paint etc. Not sure if that's a scare tactic or something but I would think they should be able to get a color matched bumper from the factory?
Fosscore
I have rented quite a few 15/16 models and not seen the bumps either. Not being able to color match the OEM paint is pure BS! Sure maybe the bumper comes primed ready to paint as it would be cost prohibitive to inventory all the colors for every part for every truck. No worries. But anything can be color matched. The newer the paint, the easier as it hasn't had time to be destroyed by UV, etc....
I have had my 06 Dark Ming Blue Metallic and my 13 WDT color matched perfectly as have many other trucks on here much older than yours. Tell that guy to get his head in the game, get you a bumper and paint it. If he can't match the color (too lazy) make them order paint from automotivetouchup.com or any top notch body shop can computer match what the code is and mix it up.
SMH....Good luck. Let us know how you go.
Woodman-LTZ15
Wife just curbed on of the 22s" as well. I wet sanded it out last night. Now I need to find the right gun metal gray paint to match. Q: Anyone know the code or where you can order it?
Thanks
'15 Tahoe LTZ
'07 Suburban LTZ
dm7582
I work for a large OEM fascia manufacturer. I can tell you that looks like a mold defect in the attachment flange or sonic weld issue where if a bracket was welded to the fascia pre-factory install. Is your paint color summit white? If so color match is easier then a metallic white. The fascia are painted pre factory install, but it is hard to get a painted one vs primed.
VDV18
This is BS. Demand they get you a new bumper if the heat gun doesn't work, this appears to be a defect. Don't let them flake out on you......good luck!
Bob LaFord
