1992rs
OR
I tried loosening that nut with a wrench while holding the Allen but couldn't do it. Did you just mark the Allen somehow and use a socket on the nut? That thing is in a terrible place to get to.
It really is in an inconvenient spot. I took the cover off my ecu to get a little more clearance, but I just kept playing with the position and eventually I broke it loose with the wrench and Allen. I did mark it but between the darkness and dirt it got lost in translation.
Bombsquad85
Northern VA
There are write ups on multiple different gm forums and YouTube videos. A quick search will show you everything but you'll hear multiple different ideologies about which is the correct way. Some say have the wheels cranked, some say keep it simple and just tighten it.
You only need a 16mm wrench and a 3/16 Allen wrench (supposedly, I just dug through my drawer and found one that fits.)
What I did was loosen the nut on the box, 1/4 turns with the Allen wrench on the hex stud? while hand twisting the steering shaft to check play, and repeated until I got minimal play
Awesome thanks
@Bombsquad85 hey bud take a look at this.
Thanks!
Blue light kinda different.
Lights looks good with change out up front.
What model Pioneer is that?
@Fosscore , I was wrong.
02Burgundybeast
South GA
Installed my Valentine 1. I may mod my review mirror to house it and make it more factory looking and or hidden.
looks pretty easy I might have to give this a try this weekend
The only thing that's easy is locating it and looking at it like he did in the video. Notice he never actually loosened it or adjusted it! Youll see once you give it a try. It's at a bad angle. Looks easy though you're right about that.
ASG-MikeS
