Power steering leak
arens6
Navarre, FL
Need some help tracking down a power steering leak. I have a 2004 Tahoe, 5.3, 2wd, and towing package. The leak seems to be almost dead center under the Tahoe. I check the power steering fluid level (and all the others just in case) and they all appear to be good. At this point I am unable to see where it is leaking from. I am guessing the pump but not sure. Are there any other places it would be leaking from? I do not see any evidence of leaking from up top. Thanks.
A
arens6
Navarre, FL
Added pick of the top and bottom of the pump. I don't see any leaks. I also added pics of where I see evidence of a leak but cannot tell where its coming from.
Larryjb
Considering the gear is bolted to the left frame rail, I doubt it's the pump. If you have a skid plate, I suppose it could be leaking from the pump onto the skid plate, then running towards the center. I'm not sure about a power steering cooler. If the lines run over the skid plate, or over the center of the truck, I suppose that could be a possibility.
What about a leak from the transmission cooler lines?
Larryjb
Also, what about the possibility of a leaking brake line?
In the 2nd picture, I see the fluid dripping off the center link (relay rod). Just about that are some lines protected by a plastic cover. I can't remember what's in those lines, whether they're electrical, brake, or transmission fluid lines.
A
arens6
Navarre, FL
It leaking from directly above those covered lines. The fluid color is the same as new brake and power steering. Not red like I am used to seeing for transmission. I was able to see a little fluid on the bottom most pulley.
But, power steering cooler....I never would have thought to look for one. Will have to look for that. Thanks all.
A
arens6
Navarre, FL
after cleaning everything up and laying down a fresh layer of absorbent material I do no see anything leaking this morning. I'll keep watch where I park at work and home to see if it starts leaking again. Thanks all for the ideas of where to look.
Drewphil
