Transmission Cooler and Gauge
crunk
I have an 03' burban with the stock transmission cooler but not trans temp gauge. I have a budget of $150 and want to upgrade the transmission cooler and add a trans temp gauge.
What should I buy and is there a DIY guide for this?
I came across this for the temp gauge which leaves me with ~$70 for a new TOC. Is this legit?
TheAutumnWind
Thats not bad for $80.
I feel like with a $150 budget I'd just get the best trans cooler I could and forget the temp gauge. $150 gets ya the tru kool 40k which kicks ass.
David Paul
Central NJ
It's legit. I added it and it looks OEM because it is. Turn around time was quick.
Pretty sharp! ! I'm sure a few guys would be interested in a how to , including myself .
Chip18
Dayton NV
Uh yeah! Where did the White Face Gauges come from to start??
And this bit "LED white stripe lighting for my gauge lighting." What's the deal there?? Details please. :)
dhulsey779
Phila
Believe I purchased both the gauge face & lights off Amazon. Soldered in all new steeper motors (7 total).
LED stripe was a bit tricky. I cut it off in sections where is was able to stick to the plastic backing of the cluster. Then I soldered it where the bulbs would connect. I'll have to look for additional pictures of when I completed it. But here's the parts I purchased.
Chip18
Dayton NV
Thanks. :)
Smoke Em All
Taylor,Texas
When I did the bulbs they required resistors. Without them you can't dim the bulbs with the dimmer switch. Can you dim yours?
yottybaby
