2003 tahoe power window wiring diagram needed please
tahoemark
Hi!
Does anyone (please) have a wiring diagram for the power windows on a 2003 tahoe? I've got the Chilton manual which has many wiring diagrams, but nothing for the power windows. Went to the library, searched the internet best I could but can't find...
My problem is the right rear window will not go up from the drivers switch. Goes down from drivers, and goes both up and down from the passenger door switch. Took both door panels off and have looked for problems. Too many little wires for me to figure out on my own...
Thanks!
The problem must be the switch in the driver's side. Can you swap out the passenger side switch to eliminate wiring problems or are the plugs different?
I have the 03 wiring diagram but it's too large to add it here. PM me with your email address and I can send it to you.
Here's the part that applies to the window switches:
T
tahoemark
Thanks for the pic as that's step in the right direction but that doesn't look to match my switch. Note in the bottom it says Body Control Module and it's got signal wires for door ajar, power brake and such. It does give me some clues though as I see reference to the RR up and down but the driver door switch/module I have controls 4 windows, 2 mirrors, and the door locks.
T
tahoemark
Good idea but no, the switches are totally different. The drivers side has circuit boards and multiple connectors.
T
tahoemark
Thanks very much for that document. It seems to have everything except the window motor wiring. :) Just the way things going for me. If anybody has, I'm still looking... thanks.
Juggalocujo
I am trying to find out which wires/pins control the LED lights inside of the Driver door window switch on a 2003 Suburban 1500 5.3L.
A diagram would be greatly appreciated!
Thank you.
Email to [email protected] thank you again
It will not let me open it, or save it, or anything. That's why I asked you to email it to me.
I just need the pinout. PLEASE?
I don't even know where I got that diagram anymore. Screenshot, or get on a computer. Sorry I did the best I could do.
Toebob
Hi!
Thanks!
Have you found out the issue? I’m having the same problem.
CKendrick
