Yea that too. I assumed by checking for power one would check the ground in the connector. But forget not everyone thinks the same as me.
Sent from my SM-N920V using Tapatalk
Most people forget about ground. They check for +12 volts and that's it, not realizing that just because their meter or test light is grounded doesn't mean that what they're testing is grounded.
Thanks man! You have the Denali correct? Man that thing is so clean!
No , I have a Tahoe , but thx, lol .
ATIII
Brighton, CO (Denver)
Installed a HomeLink over head console. It was plug and play.
Well you cost me $30 for one of these now, lol. My wife's Trailblazer has it, and I didn't know it was an option for ours. Oh well thanks, at least I won't have the opener on my visor anymore.
Fosscore
Got the rear hatch handle changed. I will try to get the others installed tonight.
Looks good. Time for the wiper arm to disappear and color match the push button ring. Would tie in nicely with the Esky 3rd brake light and roll pan. Nice work.
:2cents:
Da90
Tulsa, OK
:2cents:
I agree. Once I put the handle on there the wiper and button stuck out big time. I've been kinda holding out on paint until I complete a few more things. My vent caps need painted again and also I don't like how the vinyl turned out on the third brake light. Basically the whole back of the truck is going to get a repaint. For now it's going to stay.
The front bumper on my Denali is driving me crazy and that's the first thing to get painted!
Da90
Tulsa, OK
I also put sound deadener all over the back hatch last night before I reassembled the plastics. When I do the other door handles the doors will get sound deadener also!
Fosscore
I hear you buddy. Not that you needed any advice with your build, just throwing stuff out there as everyone pushes for the next mod or little thing you haven't gotten to on the never ending list lol...have a few niggly things myself that I want to do too, but have to wait. Looking good though.
Plugs (hated and loved) are a quick and easy way to ditch the wiper arm now for less than $5. A proper shave like Red Rocket just did just takes a little extra money, quick weld and body work then paint that whole back end while you are at it. Will look $$!!
osiris94ej
Casper Wyoming
Needs less chrome and some wheel spacers. Rear end is sagging because of the almost 500lbs of wheel/Tire in the back.
Annd since I couldn't think of any other place to put it how do you come up with used wheel pricing? Not sure how much to sell my 18x10's and Cooper A/T 3 as a set. Tires have less than 3k miles on them since Cooper replaced under warranty.
BigDaddy13440
Rome, NY
If you weren't almost all the way across the country, those 18x10's would look really nice on my Yukon XL.
TheAutumnWind
Thanks! I think I'll go ahead and be spraying the bolts for the next few days in hopes they'll break loose easier
Thats a good idea. I had absolutely no trouble with any of mine, but I am in CA and get no snow.
Ordered a Derale deep transmission pan from a forum member. Holds over 2 extra quarts and a drain plug plus has cooling tubes and is supposed to drop temps quite a bit. It might be awhile before I install it though since I had the filter and fluid changed not long ago.
Phlipnstik
