Windows rattling?
lynxnova
New Jersey
What's up my fello hoes and kons, I own a 2010 tahoe LT and all my windows are lose and rattle, even my back window... I've taken it to get checked and tighten up the regulators but when they are halfway down or all the way down they are extremely lose and rattle to the point where I just keep them closed all the time.... has anyone experience this and how can I fix the problem.... even my back lift gate window rattle...smh..help...
Sent from my SM-G920V using Tapatalk
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
It's a standard feature of these trucks these years. Mine does it too
L
lynxnova
New Jersey
Wow... I can't believe that... I mean, I can literally move my window with my hand with ease....I think it's time for me to sell my tahoe and think about an upgrade to the 2015... unless they have the same issue
Graystone_OG
NYC
Wow that's crazy. Thought it was just me. I literally have to tell people to hold the door from slamming, just to avoid this near glass shattering sound.
fiatdale
Houstons Best
Houston
You're saying the fronts and rears? Fronts have an extra channel that the tears don't to keep it from moving. You sure all the weatherstrip & beltmoldings are all good? I won't disagree about the rear windows. Single point of mounting for the regulator so it has tons of back and for slop when down. Never had an issue with the fronts though.
Graystone_OG
NYC
I would have to take a look on mine. I've never disassemble the panels before. The passenger side glass was replaced before I got the truck.
fiatdale
Houstons Best
Houston
It's held in by a single 10mm toward the front of the door. Maybe 3.5" long.
L
lynxnova
New Jersey
The sound was so nerve rackin, that I replaced all weather strip and window regulators on all four windows (done by a window auto shop) and it still rattles alot.... I can move the window back and forth with my hand.. I never had a problem with my window when I had my 03 yukon..
fiatdale
Houstons Best
Houston
If you're talking about the fronts - then something is not right because my fronts are as tight as can be, at any opening. Rears are only tight if they're closed.
L
lynxnova
New Jersey
Yes.. I'm talking about all my windows, especially the front.... I'm gonna have to see if another shop can give me another option
fiatdale
Houstons Best
Houston
I've removed and installed a zillion of front door glass & regulators, belt moldings, glass channels, etc - never had any issues with the fronts being loose.
L
lynxnova
New Jersey
So aside from the regulators, what do you suggest I should do? What are belt moldings and glass channels?
fiatdale
Houstons Best
Houston
Belt molding is the black piece on the outside of the vehicle at the base of the window. Glass channel is the extruded piece of aluminum that goes around the window opening in the door. Make sure all that jives together along with the weatherstrip at the base of the window on the inside of the door (under the door panel)
L
lynxnova
New Jersey
Great.. thanks @fiatdale.. now I will sound like I know what I'm talking about when I take it to the shop
bill1013
Air Force EMT/First Responder Firefighter
Waianae, Hawaii
Did this fix the issue? Our 2014 Tahoe's windows rattle.
How are the window wiper seals? The ones with the window all the way down you should see them. They should press against the window as it goes up, thus keeping water from getting to the bottom of the door and rotting it out. There should be no gap at any time, window up or down. The wiper provides enough pressure against the window to keep it from rattling. The seal on the back lift window should protrude out a little to provide a seal against rattling and water. The older your ride the worst the seals get and should be changed. I've been Armor-alling my 2012 in hopes of keeping them supple enough to last a few more years. But nothing lasts forever! Hope that helps.
Dianet804
Thank you!! I'll have that checked! I have had water in the doors after a heavy rain too so that makes sense!
veteran111
