osiris94ej
Casper Wyoming
That's what I'm hoping for. Need to pick up clear and some 320 sand paper to strip the paint that is currently on them off.
You shouldn't have to strip it all off. If the paint is properly adhered then all you need to do is scuff the surface and use that as your base. It will stick as long as it's smooth and not glossy anymore.
Sent from my SM-N920V using Tapatalk
pnwdan
Cunning linguist
Arlington, WA
Good advice. You won't get better adhesion than the factory primer already has.
TheAutumnWind
Didn't check the Moog's, I was looking at the Fabtechs. $$$$$$$$
I'm thinking about trying the rough country tie rod sleeves. They are like $35 seems like a pretty inexpensive upgrade.
Edit: hrm I'm reading that they may not work with moog tie rod ends. I'll have to do a bit more research before I take the plunge.
DarkBlueHoe95
West Columbia, SC
They were originally pearl white. But a coworker of mine painted them dark red cause he put them on his 01 Yukon. I sanded them down the first time with 500 for him but he didn't use any primer when he painted them and used clear coat for wheels. So I felt it'd be best to take off all the clear and red he sprayed before I tried to paint them because I want them smooth as glass and flawless. So I plan to strip them down to factory coating then spray primer, paint, then clear them. Hopefully have a good outcome.
Looks like that's true since it says this on Rough Country's website:
(too bad, I was excited for a minute there)
Notes
  • Works with OEM tie rods ONLY
DPGDirk
Notes
What would be the difference? If the Moog TRE screws onto the same tie rod, it should be an OEM replacement. Not sure why the new sleeve wouldn't work.
I'm also not seeing a big benefit with the sleeve itself either...
ATIII
Brighton, CO (Denver)
I also didn't see any major benefit of them, and I was also under the impression that the moogs were a direct oem replacement. They look exactly the same as the stockers when I changed mine. I'm holding off for a couple months and getting the Rare Parts ones. The video I saw of OEM vs Rare Parts sold me!
http://r.ebay.com/sihWQU
I haven't had a problem with my Moog ones and I think those Rare Parts ones are way overpriced so I think I'll stand pat. Rare Parts are making a killing on those.
DPGDirk
To be fair, I can see the superior strength of the RP parts, but how often do we see these parts pulling apart or failing based on strength?
If that's not an issue, then it would seem to me that the question is- How long do the Rare Parts components last/wear compared to stock?
Will they go a lot longer before showing wear or will that be similar to stock?
From what I gather, most of the heavy duty steering pieces are built with the off-roader in mind, where not only are they running big tires but also hitting big bumps and other obstacles where you might actually bend parts. I may have 26" rims but if I ever hit something hard enough to bent the tie rods, that will be the least of my worries since my rim will be bent and my tire flat.
donovandavis
Not sure where this would go but I'll go ahead and post it here. Swindled my mom into getting a '15 SS. These cars are super super nice and I encourage anyone that has an opportunity to drive one to do so. Stock for now but I have black bow ties and tinted windshield coming in the next few weeks
An SS what?
donovandavis
Jokes??? Can't seem to decipher lol. Countryboy07 is correct, it's just a standalone SS model, I figured most of you would know what it is. It's the Pontiac G8 GXP's brother. Ls3, rear wheel drive, mag ride, available in a manual, etc.
I was unaware. My friend bought a '15 Camaro SS and I knew it wasn't one of those.
osiris94ej
Casper Wyoming
About to install yet another damn window regulator assembly.
Not sure how you feel about the oem part, but I've had bad luck with the aftermarket regulators through the shop I used to work at. Stopped selling the Dorman, and starter buying the Delco from Rock Auto and usually no issues unless the window guides need adjusted/lubed.
ASG-MikeS
