V8 & V4 .. showing on DIC
Someone
Kingdom of Saudi Arabia
Why does sometimes it shows V4 and sometime V8 on the DIC. (see pics)
[I have recently bought 2015 Tahoe LS 2x4 without user manual]TAHOE1.jpg TAHOE2.jpg
PG01
Up here to the right
DOD displacement on demand, AFM Active fuel mgmt, shuts of 4 cylinders to give you better gas mileage........hahahahahahahahahahahahaha.....do a search on here for AFM or google.......lolololololololol
Glocksub
Exactly. My advice is to disable it using a range device, superchips or diablo programmer. It will drive better without it and most report that the change in fuel mileage (if any) is well worth the improved drive ability.
jeffbco
Obviously his selling dealer didn't explain the "benefits" of AFM or he didn't get an owner's manual.
Active Fuel Management®
Vehicles with V8 engines may have
Active Fuel Management. This
system allows the engine to operate
on either all or half of its cylinders,
depending on the driving conditions.
When less power is required, such
as cruising at a constant vehicle
speed, the system will operate in
the half cylinder mode, allowing the
vehicle to achieve better fuel
economy. When greater power
demands are required, such as
accelerating from a stop, passing,
or merging onto a freeway, the
system will maintain full-cylinder
operation.
If the vehicle has an Active Fuel
Management indicator, see Driver
Information Center (DIC) 0 152 for
more information on using this
display
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
On paper it's a great idea. Real world use is doesn't work. Sure if you let off the gas or coasting downhill will show all day long. Touch the gas pedal, back into v8 mode
Z15
Michigan ,USA
Its a more fuel saving device for GM CAFE then for the customer. Its things like this, 8 & 10 speed trans or a V6 like Furd.
Laurents10
