new to forum need help with wheels an lift combo
HALE03YUKON
wichita ks
Hey guys new to forum and need some help i have a 03 yukon slt 4x4 i'm looking at a ebay lift kit 3" keys 2" spacers and some 33/12.5/18 or 33/12.5/17 can't make my mind up on which ones to go with friend of mine said if i go with 18 i need a -12mm offset i would like to go with 17x9 but don't know if that offset will work on that size rim just would like to get some input and maybe get some pics of your guys set ups if you guys can as I'm new to the 4x4 world I'm more of a drop'em kind of guy but time for something different
Please if u can post some picture if you have this kind of set up
Thanks guys
AH64Medic
South Carolina
I have a 2000 NBS suburban 4x4 that's at stock height with 17x9s and 285/70/17 which I think is a 33" tall tire but not quite as wide. 33x12.5-17 will look good on your truck. Good luck
H
HALE03YUKON
wichita ks
So if your sitting stock with 33s you thank i can put 35s on with that lift and not rub or are they going to be to big.whats the biggest tire i can go with?
Leedogg
Brewton AL/ Pensacola FL
I am running 35's on a 6" RCX lift- and they still scrub. The general consensus is 33's for the lift you are getting- and you may still scrub a little up front. the 12.5 wide is what gets you.
middelgriff1
Maryland
I have 33s on 17s 0 offset with that lift plus a 1.5 body lift. The tires barely stick out of the fenders so a -12 offset should stick out 12 more mm's. It barely rubbed without the body lift, just had to cut a little of the liner out and round the corners of the lower valence.
H
HALE03YUKON
wichita ks
middelgriff1 you have any pic of your truck you can post if not its cool you thank i can use a 0mm offset on 18"wheels with 33s
middelgriff1
Maryland
Front and Back 17x9 0 offset 33 BFG AT
Mol
Columbus, OH
305x55/R20, -12offset (33.21 inches)
No lift, cranked the torsion bars about 1/2-3/4", and used a sheet medal blade and BFH to trim the rear of the front wheel weels/front of the running boards, and a slight trim to the plastic on the inside of the front bumper.
Yukonboy2014
I did the 2.5" up front and 1.5" spacer in back. Wheels I put on were 17x9 addicts, not sure bout the offset. 33" tire. I know that if you get 12.5" wheels theyre gonna stick out a whole lot, not sure if that's what you're looking for or not. Going from a stock wheel to a 17x9 for me, it stuck the tires out maybe half an inch to an inch from the wheel well. It looks pretty good to me, but imo the 12.5" on my rig would look stupid. All my opinion :) Oh, and my car actually sits higher in person than the pictures show. And I could not run a larger tire on my setup, the BFG's rub when the steering is all the way locked one direction or another.
YukonXL04
The Riverboat
Arlington, TX
What's your overall height to the top of the roof rack, not including the cross bars? Also what's your fender heights?
SDHanz
