Misfiring, runs like crap in morning
Cpurp31
1999 5.7 ppv.
Changed cap and rotor plugs wires and at times it will run like total garbage missing a backfiring.
Other times at 55mph and up it will almost studder or hesitate for a second
Plz help
C
Cpurp31
AEE245E6-C871-4C4F-8303-779EC2FE571D.jpegI’d say so smh
exp500
Any P0300's or P1345?
Have you updated the engine grounds? You are running two posts now. Coukd be connected.
Multnomah Falls
Vacuum leaks? Cat convertor problems? O2 sensor problems? Did all those codes come at the same time?
exp500
Post #5- Not sure that issue fixed yet. Could be connected.
C
Cpurp31
I think it could be connected. Idk if the ppv’s came with a push button start but this one has one. I’ve ran new wires since then. I’m going to check body grounds tonight
C
Cpurp31
Yea all codes came at same time. Could be a vacuum leak. I’m just hoping it doesn’t have anything to do with injectors
exp500
Add a can or two of berryman. See if it cleans up the injectors. You already have the updated spider.
waiteben84
