laredo1307
- Joined
- Dec 17, 2013
- Posts
- 86
- Reaction score
- 34
Hello Gentlemen,
I'm at a loss on trying to find the source of my misfire. The strange thing is it only happens when I fire it up in the mornings and will last my whole commute to work, which is about 30miles. It only throws a P0300 code and something is definitely telling it to dump too much fuel. By lunch time I can go out the truck and it will run just fine. My commute home there's no issues, runs like a top. I have about ~316K miles and the crank, heads, intake are all original. Otherwise every item you can think of including the fuel injection (updated model) has been replaced. Most of it about 50K miles ago.
When it's misfiring I've tried spraying started fluid every where but can't seem to find a vacuum leak. I'm going to borrow a smoke machine next.
Things I've tried so far.
- Replaced cap, rotor, and plugs. Wires appear OK
- Replaced the intake coolant sensor
- Checked the PCV valve, seems good
- Swapped the MAF out with my old one (I think is still good). Getting the same results
I have the Dash Commander app and both the MAF and MAP seems to be operating within their limits. This morning on the way in my fuel trims were all over the place and my O2 sensors were reading rich. Just now after sitting an hour I went outside and my truck is running normal. Fuel trims seems to be inline and the O2 sensors are reading much better. The only difference I notice is the Intake Temperature seems to be reading much higher. On the way in it was around 90F but now that the truck is running ok it's reading 118-122F. Of course it has warmed up outside and the truck is now sitting idle. I live is Houston BTW. I also have a new temp sensor on the way.
Just seems like it has to be a faulty sensor or maybe a vacuum leak sense it only happens in the mornings. Of course if it was a vacuum leak you think it would go away after the engine warms up and not after my drive and it's been sitting for awhile. If it was the fuel injection wouldn't it be happening all the time? Another thing I noticed was Sunday I didn't start my truck till lunch time and it was considerably hot outside. Truck ran just fine while I ran errands around town.
Things I'll check this evening.
- EGR valve (2yrs old)
- Fuel Pressure
- Replace Air intake sensor (2yrs old)
- Check Map sensor (2yrs old)
- Check Canister Purge Valve
Any suggestions would be great.
- Fuel Pressure
