Mike's 2013 Tahoe Build
Goodinblack
I Like Tacos
Dirty South
My Suburban is sitting 36 all around pretty much.
Hope to have it 35/36 some day.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Different springs used in different trucks. This is why you get more drop on some trucks than others.
ie my front esclade sits at 33 7/8 thats with a 2.75 inch drop about.
in rear stock was at 38 9/16 where as now it sits at 34 1/2 about a 4 inch drop.
Some autorides sit higher than others I noticed also spring part numbers vary. Either way we will soon find out on measurements who knows I might be way off.
mjenk430
mjenk430
Unionville, VA
I'm 4x4 also.
Last time I measured (after my alignment) it was: (posted back on page 4 or 5)
FL 34 3/8" FR 34 5/8"
RL 34 1/8" RR 34 3/8"
I've lengthened the rear autoride links since then but don't recall the measurements, I'll try to get it tonight.
Josh, are you running a 295 or 305 tire? That makes a small difference also.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Hum rear looks higher ten that on above pic. Nm saw you changed the links.
Blazed
Accepting Donations
I'm running a 295 tire.
But idk if it should be a 1 inch difference.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Like I said not all springs used are the same some models sit higher depending on springs used from gm. Some trucks sit as high at 38 9/16-3/4 stock in rear
Goodinblack
I Like Tacos
Dirty South
GM uses a Plethora of shocks.......... There are 8-10 different listings for every year.
I found that out when I was recently researching them.........
Blazed
Accepting Donations
I think mine sat at 38 in the rear and 35 in front stock because my rack was so terrible it was sickening. And I currently have two inches of rake and can't complain.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
yeah yours sat low for sure stock. WOndering if yours has the hybrid part number on the springs?
gmdealerguy
