factory vs custom cooling fan on/off temps?
Wrisktaker1
Wrisktaker1
Waldorf, MD
right but I live in Md where its gets cold so if I lower my on?off temps will it heat up enough to boil off the condensation and not have blow by from never fully being warm?
Wrisktaker1
Wrisktaker1
Waldorf, MD
ScottyBoy would you mind taking a look at you your temps and tell me what they are as I'd like try your settings, unless it's a secret
YukonXL04
The Riverboat
Arlington, TX
Mine are set at whatever black bear sets them at when they tune it. Works great. Almost never hear them running. They are quiet. But my truck stays at 190ish even when sitting for an hour with the a.c. on. Love them
6speedblazer
These trucks have humongo radiators compared to other platforms i have built. they should have no problem staying at or around thermostat temperature even with the higher temp fan settings.
now something like a TBSS or an LS swapped s10. those get hard to cool due to the tiny space for a radiator.
SnowDrifter
Washington. The desert side not the Starbucks side
I'm set 212 turn on / 207 turn off for low speed
218 turn on / 212 turn off for high speed
I've found that the low speed setting keeps them on in stop and go. Helps draw air over the p/s, trans cooler, and blows air over the alternator and whatnot. Once I get going, temp drops to 204 and fans turn off
2011SSVHOE
I'm an egual oportunity offender
The Heart of The Triad, North Carolina
Interesting, In my SSV, when I use the remote start with the a/c on those fans kick on after about 30 seconds. maybe because of the extended idling for LEO'S and Fire fighters, they kick off after I get going. anybody else??
6speedblazer
fans kick on based on AC pressure
Pepper1700
