longstand
- Joined
- Sep 30, 2010
- Posts
- 382
- Reaction score
- 0
Still having problem with my steering.. i have change the power steering gearbox, pitman, idler arm and where it connects to.
i change alot of major part. and still hard to steer, specially when the engine is at IDLE.
.. the first time i started tested the steering it was nice and smooth. after a few turn it started to get harder and harder sometimes it will not even move until i give it some gas but still hard to steer.
I dont have a Power Steering ASSIST feature i dont belive. because i have a regular Brake booster.. i think thats how you could tell. and the guy at the autozone told me the same thing...
When i change the Power steering Hoses on the Pressure side of the Power Steering PUMP. i have notice a sensor.. what is that.. a Sensor next to the Steering PUMP HOSE.??
maybe its my Power Steering PUMP
Also. it makes a GRINDING sound. like a door without lubrication. on some of it turns.. not all turns. but only when i go left when the steering is slightly on the right side of the car
By the way.. when i drive the drive. the power steering work fine. it only give problem when the car is not moving or when there is alot of pressure on the front..
I lifted the front and steer. it was perfect..
I also Disconnected the return hose on the power steering gear box and see if there is alot of Fluid coming out and its not block.. and yes fluid flow really good.
