qukon 95
:thumbsup:Well after a cut on my left hand thumb looking in tool box and one on right hand thumb while taking out ujoint I installed the nickel plated slip yoke and test drove it so far so gooood no clunk
Or shifting from a full stop then accelerating
95escahoe
Got the pass side Denali door panels in and heres the driverside seat bottom done (just need to cut out the holes in it) and missing the one speaker grille was cleaning it
_Dylan_
STAY FROSTY
Went to change the leaky schrader valve on the low side a/c port, but it was completely seized and I broke the tip right off it. It ain't coming out now.
The good thing is GM in their infinite brilliance designed the serives ports to be welded the manifold so I gotta replace the entire suction and discharge line assembly, yay!
Instead they could've used something like this:
The whole a/c system needs to be rebuilt anyways...:poop:
chaingun427
OBS Mad Scientist
Mooreland, OK
541b37335ad8c34c414454d585f4ec4e.jpgbd326b57220ba424fb3fd9d09ebf1059.jpg finished installing the floor shift for the 4x4, and cut the hole for the trans shifter in the carpet. Trying to figure out Hoe to get the carpet back in smooth street it was cleaned
95escahoe
Installed the pass side Denali woodgrain bezel, need to take it off and fix a damaged clip on it tho, so it fits better
SunlitComet
OBS Jedi-Do Good
unknown at this time.
I would have said replace just the valve core but that port looks like it may not be that cleanable and might have plugged the orifice valve in the process.
kurv3
