I wish I could score the '21 PPV brakes.
I ordered the standard '21 Tahoe front calipers. They're a fixed 4 piston caliper, they got a ****** shit ton more clamping power by design.
I still need to get pads and rotors....but those are easy to get. The calipers have been on a national back order and are still hard to get now.
The ‘21’s bolt right onto the NNBS? Need brackets I assume.
Nope bolt right in with a single washer. They're a fixed caliper, so no bracket.
The caliper bolts to a bracket that’s attached to the knuckle in the front or backing plate in the rear. So these bolt right to the NNBS brackets? I know when I upgraded my NBS fronts to NNBS calipers and the larger rotors I needed to buy the corresponding brackets. Some calipers come with them included, some don’t. When I look up the part numbers you ordered I don’t see them included.
1BADI5
DMV
There is no bracket, its a fixed caliper that bolts directly to the spindle/knuckle.
waiteben84
