Tech 2
96-2D-Hoe
96-2D-Hoe
Plugged the AC into the bottom of the main unit.
I left my interior lights on and so am charging my battery so I can't try it in the truck right now.
96-2D-Hoe
96-2D-Hoe
I'm not getting 12v from the AC adapter so hopefully that's all it is.
96-2D-Hoe
96-2D-Hoe
AC adapter is definitely dead. Just hooked it up using the battery cable adapter and it starts up fine.
I'm guessing this adapter goes with this cable. But what I don't get is how does it actually make a connection when there are no pins on one side?
I just found out. And now I know why it's so tough to get them together. I did take a good look before I asked, honest. Still can't get it them to snap together though. Hopefully will work anyway.
St. Louis
Mine are super tight and never really "latch" together, but work fine otherwise
push harder, I would say hit it with your purse but this isn't facebook :fishing1::Good or Bad:
96-2D-Hoe
96-2D-Hoe
I already tried hitting it with my purse. I even greased it up with oil off my nose. It's 1/16 off. I think it will be fine.
ya they are pretty snug try taking it apart and putting it back in a few times and then push till the clip holds it together
96-2D-Hoe
96-2D-Hoe
Well, I'm not having much luck. The ABS bleed function doesn't even show for a 96 or 97. Shows up at 98 but screen goes blank and nothing happens if I try it. When I try anything it either says it lost communication or the screen does nothing. And the screen contrast has reset twice now.
Anyone used this on a 96 or 97?
xmen_1217
