LED brake lights and no cruise control
BG1988
Yea I hear the 07+ are a pain if you want leds for anything. Outside and inside lights. But still ways to do it
No , there is factory LED brake lights available it's 160$ each for new ones Genuine oem
(Tahoe version not the caddy ones)
https://www.gmpartsdirect.com/oem-parts/gm-combo-lamp-assembly-22837838
https://www.gmpartsdirect.com/oem-parts/gm-combo-lamp-assembly-22837837
you will need to replace the
APPLIQUE D-PILLAR but it will be fine with out
but it's a upgrade to the 2015 look
05Single
afraid of the dark
BG1988
Nice, I didn't know they had that option:waytogo:
it actually better then the Cadillac ones
the Quality control is much better with the tahoe ones.. My 08 has no burnout ones.. original tail lights I have test drove two others the LEDs were good in those as well.
the Cadillac has so many rows the quality control had to go down and it seems the plastic with the Cadillac is of poor quality(cracking issues and dead LED rows and or dead diodes)
other wise they would have too many faulty units and the cost for them would be even higher then it is
they are really bright as well brighter then the
Sylvania Zevo
these LEDs are heavily used as well because of the ReGen braking turns on the brake lights
Blakepearce15
I have a 02 Tahoe and I have led tail brake lights and a 3rd led brake light, the cruise control stopped working, but after I put resistors on the brake lights the cc light started coming back on but only until I got 20 mph
I don’t think it will work under 20…..that’s not cruising that’s crawling. :D
Edit:25 mph. Here’s the owners manual:
gmdealerguy
