Best Cheap/Free Mods?
BlueCollarTahoe
For my broken LT fog lights, replacing them with LED's was a 30 minute job and cost ~ $20. LED lights bolted right into the housing for the factory fogs.
I'll put it here for everyone to see.
https://www.amazon.com/Senlips-Ligh...rd_wg=brbYZ&psc=1&refRID=A6C836CAE2829PBK3P0M
Price has dropped since I got mine. these are about $14!
I have these. Bright.
yooo these are nice. are they plug and play or you have to mess with some wiring? can any of yall put some pics of that if you have to? or a pic of the wiring it comes with?
BigDaddy13440
Rome, NY
These are the 36 watt ones I've had for two years:
https://www.ebay.com/itm/2x-Quad-Row-7Inch-480W-Led-Work-Light-Bar-SPOT-Offroad-Driving-4WD-Truck-ATV-6/262956764592?ssPageName=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
I ordered some 480 watt lights to replace the 36 watt ones, the 36 watt'ers are going under my rear bumper for backup lights.
(40) 12watt LED's in each light vs (12) 3watt LED's
I'll be able to see for miles!
I'd love to have those lights below my rear bumper for tail gaters!
Martinjmpr
Littleton, Co
Well I wouldn't call them "plug and play" but they're pretty darn simple. Pull out the old socket and bulb, cut the socket off leaving two bare wires. The LED's just have two bare wires as well.
Connect wires together , seal up with electrical tape (if I did it now I'd use shrink tubing but I didn't have a heat gun when I did mine) and then bolt them in. For added protection I put the wires inside split wire loom and taped that up as well.
I ended up using the bulb socket for the bolt that holds the lights in so I drilled a 3/16" hole to run the wires through. They've withstood a couple of Colorado winters and some mild off roading since then.
I think the whole process took me maybe a couple of hours but I work pretty slow.
ETA: You also have to remove the old reflector, I did that with a pair of snips.
Here's how i mounted mine. I don't use them much, but when I do, I don't notice them shaking/vibrating at all.IMAG0896.jpg IMAG0895.jpg
Iirc, I added spade connectors to the pigtails coming off the fogs, and plugged them into the factory plug and taped them up really good. It's been 1 1/2 yrs, and no problems yet.
levilarsen
Here's a day shot.View attachment 193127
Here's how i mounted mine. I don't use them much, but when I do, I don't notice them shaking/vibrating at all.View attachment 193130 View attachment 193131
Night shot.View attachment 193134 View attachment 193135
Are they weather resistant I've heard these ones are sealed and I've heard there not I can't get a straight answer
Sent from my VS995 using Tapatalk
csan2879
