Autoride bypass sensors
Bigjimmy
I've replaced Autoride with Bilsteins front(adjustable)and rear(also Moog springs in rear and a front level spacer.It rides great again even with 270/60/20 Nitto All Terrains
The rear plugs for sesnsors only have 2 wires so that was straightforward to cut and fit bypass modules but front plugs have 3 wires and I'm a bit hesitant to cut anything before I get a bit of advice
Vehicle is 2008 Yukon Denali XL
Any help much appreciated
Bigjimmy
Bigjimmy
Thanks he's the guy whose given me lots of good advice and parts numbers etc in the past I was trying not to bother him again though....
Bigjimmy
Bigjimmy
Not heard back from @01Konvict which isn't like him,maybe on vacation or something.
Does anyone else care to pitch in with the info?
01Konvict
Boats n Hoes
Raleigh/SML
Sorry boss been away for a few days haha. As far as the new models for resistor bypass on the front shocks it should be only two wires. Here's a video that shows how to do it. Use heat shrink instead of tape though and I would prefer a crimp on splice joint instead of wire twisted together. Only unknown is what resistor you need to remove the compressor. I would remove the fuse in the under hood box to start.
01Konvict
Boats n Hoes
Raleigh/SML
Definitely 3 wires!
From the video and compared to your picture I would suggest the yellow and green wire. Not sure what the third wire does unless its a trace wire. I would test the resistor by placing a soldered wire into the female plug ends testing each of the two wire circuit combinations until it clears. Then use a quick splice connector on the wire side for long term install like th pics below. It wont hurt the computer because its a resistor and doesn't input any power. Definitely different for those euro models. How about a few pics of the whole truck?
Brian12019
