Kyle Pezzetti
no I am up north just south of Sacramento those fires are down south by Los Angeles, the fires earlier this fall were about an hour west of me, smelled smoke a couple days but that's about it, there is nothing to burn around me except grass it's mostly all farmland around here.
Where are you at ibgrew up in elk grove then was in Lodi for five years...moved up to Washington 2 years ago
Kyle Pezzetti
Got an updated tune for the Tahoe just went for a spin. About 20 miles 5 of it freeway and about 5 min of ideling in a drive through... I wasn't driving like a grandma and got 17.2 mpg best I could get on that route in grandma mode is 15.4
This has AFM turned on the one with AFM off got 12.5 full grandma drive on the same route
ddubdb3
some front fender cutting for more clearance 5e4988b3a7074d10dc7d9b122b809fe0.jpg
PG01
Up here to the right
got my dual battery setup installed, was easier than I anticipated, hardest part was trying to figure out the starter cable routing so I just poked my head under the ex wife's 04 burb and figured it out that way since there was no information online.
08HoeCD
New rear brake rotors & pads, oil change and tire rotation.
Thinking about replacing sway bar end links & bushings.....and just might do a mild (1.5”) level at the same time.
MTN_KDA
