Subs still not working
David Smith
Savannah, GA
When the truck was on and hooked through the radio the amp wouldn't turn on, I'd rather just get a switch for now until I can get a more permanent solution
If you are going to do that, it may be just as easy to find a fuse in the driver's side dash fuse box and just shove the remote wire into one that is only hot when the Tahoe is on.
I just know if it were me, I would forget the first day to turn the switch off and I would be stranded. lol
YukonXL04
The Riverboat
Arlington, TX
This. Just hook to the accessory, red wire behind the radio. Then it only has power when key on.
ridnclean18
