Cabin Air Filter??
WRMC
Does anyone know how to replace the cabin air filter in a 2014 GMC Yukon? I cannot find it.
You sure you have one? AFAIK, they discontinued them for the GMT900. There are retrofit kits for you to easily install one, though.
W
WRMC
No i'm not sure and there is nothing about it in the owners manual. The guy where I get my oil changed told me I need to change it and said he had the part, but I usually don't buy their marked up filters. I also called my local GMC dealer and the service guy said he thinks it does. Thanks for your reply.
HiHoeSilver
Away!
Chicago
If you have it, it's under the glove box. Rectangular door with one screw at the end towards the seat. If you don't, you'll see the "cutout" where the door would be and the post/hole for the screw. Dorman has a kit with the filter, door, and screw. You can cut it open to put one in.
It could've been added by a previous owner if you didn't buy your Yukon new. Does your A/C have an odor when it's on? If neither of those is true, then I'd question the honesty of the guy at the oil change place.
If you have an odor and no cabin filter, then you might have a plugged evaporator drain causing water to sit in the box and grow mildew. There are plenty of simple fixes for this- just Google around. If you need or want to add a cabin air filter, you can buy the parts (kit) off Amazon. There's at least one how-to thread on installing this kit on this forum. I recommend getting the activated charcoal filter if any.
PG01
Up here to the right
Multiple threads on the subject..as stated.... extremely easy to do if not done already.... few screws and a sheet rock knife....
PG01
My 2013 GMC Yukon Denali does not have a cabin filter
OK, that's what I need to know. Even the local GNC dealer wasn't sure when I called them. Thanks
Again, alot of misinformation on this. It may in fact have one if a previous owner cut one in. Easy to check under the dash. Yes, from the factory certain models didn't come with it.
79jasper
Yup, to my surprise our 11 doesn't have one.
Do plan to add it.
Could be that the quick change guy just assumed it had one. Real easy to check.
Sent from my SAMSUNG-SM-G890A using Tapatalk
Spargewort
