BAMF Pri's 2005 Chevrolet Tahoe build thread
73impala
73impala
Margate, FL
Well was able to get an open box ac delco fuel pump off of amazon this past week for under 100. So I just have to get that installed now and hope that's the issue. It should at least fi her hard start because you have to sit and hold the key for it to start like it doesn't have any pressure from the pump
73impala
73impala
Margate, FL
Well got the fuel pump swapped out and it didn't solve a thing... lol The whole process really wasn't that bad took about an hour and a half by myself in the driveway Truck had a quarter tank. I think the hardest part was getting the tank straps back on lol. Unfortunately I am still in the same spot.
Truck has a hard time starting. If it hasn't been driven in like an hour and you go to start it it will just crank for a few seconds and eventually turn over.
Other issue is filling the truck up. I filled the truck up from a quarter to full today and it took about a half hour.
93blkongreenpro
Cam sensor maybe? And I think gm had a service bulletin about the filling process, but I could be wrong
Sent from my SM-N930P using Tapatalk
Edit: its going to be 1 or two things- the evap caninster, or the screen in the filler neck. The screen in the filler neck may be cockeyed if anyone has tried to steal fuel from it.
Edit edit:
Update guys. No engine light since Replacing my CANISTER PURGE SOLENOID VALVE. Cost me about $35 @ the dealer.... Also tonight was my first fill up since replacing the valve. I literally filled me truck up with 18 Gallons of gas in like 5 minutes. Problem fixed!!!!!!!! I appreciate the insight guys. Thanx to Anthony and all that replied......
73impala
73impala
Margate, FL
Well I replaced the entire canister already with the part number from the http://www.tahoeyukonforum.com/thre...you-unable-to-fill-your-tank-look-here.16989/
Vapor Canister Vent Solenoid ACDELCO PRO 214-2149
Never have had the CEL come on since owning it.
Edit: I see there is a purge valve 214-1105 going to test the current one on the truck to see if the valve is stuck. Maybe that's the issue for the hard start. I don't know if that will do anything for the fill up
73impala
73impala
Margate, FL
Nothing happened really. Gf hasnr done much but drive it really. For Christmas I got her a pioneer double din. She had a rear main leak so we got that fixed and now ive been trying to look around to see what the best basic 6/7 inch lift will be. Just want one that'll clear some x12s and 31s or 33s easily. Truck needs new shocks for sure so rather just lift it and put new shocks on then.
34383618064_183c262108_b.jpgUntitled by James Pate, on Flickr
73impala
73impala
Margate, FL
Small update looking at getting all new bilstein shocks but decided to take the money we were going to put towards them and going to get a 6 inch super lift. Also got some 16x12 scorpios that I'll run with adapters and probably end up running 265/75r16 nitto terra grapplers.
35187615306_7879190e21_b.jpgUntitled by James Pate, on Flickr
34383617294_cb8e93d79b_b.jpgUntitled by James Pate, on Flickr
35227504265_e5a503303c_b.jpgUntitled by James Pate, on Flickr
What about the hard start problem-did you get it figured out?
Off Road Pedia
