rear control arm help.
juggernaut
has anyone replaced the bushings on their rear upper and lower control arms as well as the track bar?
I got the energy suspension kit 3.3194g for the rear and want to tackle this job.
any tips or advice would be greatly appreciated.
Thank you
J
juggernaut
lol that's what I figured but I just thought maybe someone has done them here and might have advice or tips. I googled it but no real info is out there or I'm not looking correctly
TheAutumnWind
Rear control arms are dead simple on these trucks. I have not done them myself, but they appear to just be a matter of unbolting them, using a shop press to knock out the old ones and in the new ones and bolting them back in place. Sorry I can't help more than that. If I find anything ill share it.
J
juggernaut
hey either way I appreciate it. does anyone know if the track bar needs to be set or anything like that? I just want to make sure I can unbolt everything one at a time and reinstall it no problem.
If you mean the panhard bar then no there's no adjustment. Also no adjustment on the control arms.
J
juggernaut
I am not sure if it's called the pan hard bar or track bar. in a digram I saw it said track bar but it could be called the pan hard bar. can I do this with out a press is my next question. I live in an apartment and have very limited space.
It's called a panhard bar. Not sure about the press, haven't heard of anyone replacing these bushings.
TheAutumnWind
You can likely do withoit the press if you use some allthread and big washers. Ive done that before. A quick braaap from an impact and its in.
