Z85 (Air Level) Suspension Lift
SouthernAZ
I searched and read and all that, maybe I’m just missing it…..
Is there a way to lift the rear on a 2015 Yukon XL and keep the Z85 auto air level suspension? I want to do a 2/3 lift and level but the only option I’m seeing is to remove the air level system. I want to keep it but….
Thank you for your input.
olyelr
Elk Rapids, MI
I suppose you can get the shock extension brackets to keep the factory rear shocks. Might have to play around the the sensor arm length as well, but certainly doable.
STORMIN08
i would think ( having owned a 12 w/air level), that a static spacer could be used for the coil, then a static relocation bracket for the shock. you will have to play with the sensor rod length but that should not be hard. usually a 5/16" all thread can replace the rod, the ends usually pop off or thread off any way.
it should be no different for the front, spacer and longer rod...same concept. the main thing is keeping the rear shock happy
bigsquisher
