wont go into 4 lo
99whitehoe
I cannot seem to get my HOE to go into 4LO. It will go into 4HI all day long but when I try to get it into LO it just blinks. Is there a catch to getting this thing into LO.
Kolt-46
In the brush near the river.
Make sure that you're in neutral. When ours at work get stuck, we've had luck holding the brake pedal as far down as you can push it, putting the ride in neutral, and then trying to change from 4 HI to 4 LO. Good luck! Let me know if this works for you as well!
gpracer1
Phoenix
Read the manual and it explains it exactly.
How are you doing it?
You need to be moving under 3-4 mph in neutral, then hit the low button. Then shift back into drive and go. Reverse order to go back to high.
99whitehoe
I've read the manual and I'm doing what it says to do. I'll try again and see if it works.
mfinta
