Window fuse location
Bagherra
Army
Va Beach, VA
My front passenger window isnt working..the other windows work fine...so i went to look for the fuse and cant find it. The owners manual says passenger side of dashboard, but when i pulled the cover, the fuse block doesnt match with whats under the cover.
Thanx in advance!
Moderator
People's Republic of Colorado
Are you saying that the diagram in the owner's manual doesn't match the fuse layout, or that the fusebox cover layout doesn't match the actual layout?
Pic of your fuses?
it's never the fuse
IT, will most likely be one of these 3
regulator
motor
master switch
in some rare instances it could be a defective passenger switch, which causes the master switch to not work
if the fuse is popped that would likely be indicative of a direct short and a new fuse would probably short out as well.
ZaZaZazzels
