Will this Suspension and Tire set up work?
zrodie21
Hey guys, just bought a 08 Tahoe Z71 and went out and purchased the 6" BDS lift with the coil overs and some 35x12.50R22 with Some 22x12 (-51 offset) Arkon Lincolns. Just wondering how bad am I gonna scrub ? Also how much trimming has to be done? Thanks
Midnight711
I would think you would be high enough that a small NorCal would be needed. I did 35s on a offset of I think 24 or 26 and had to do a NorCal on my level. But wait until someone smarter chimes in.
Sent from my iPad using Tapatalk
Z
zrodie21
Can’t believe no one can help me out, so many views but only 1 comment
Midnight711
So since no one commented here's a video I found that would be what you need to look at...I used it for what I did
In cases the links don't work look up suburban custom offsets, hopefully this works
Sent from my SM-N950U using Tapatalk
Z
zrodie21
I really appreciate it ! Thanks
Midnight711
Sorry I couldn't be of more help. I know they show the video of putting the suburban together.
01Konvict
Boats n Hoes
Raleigh/SML
Yes rub like hell. You will need to trim both corners of front. The bumper can be trimmed up and use pro comp brackets. The rear needs nor cal mod
Tozan
Overlander
Beauregard, Louisiana
You most likely will scrub a little on the front fender well I would think the back of the fender well should be ok... On the front like mentioned you can remove the lower air dam and cut the plastic until it clears.
I am running a 4 inch lift with 35x12.5x17s and I get minimal rubbing on the back and only when hitting some pretty severe off road stuff. Like 12 to 14 or bigger drop offs while turning.
My guess is you are building a "pavement queen" so you're not likely to get into an off road situation like mine does. I would also think with 2 more inches of lift than mine has you should pick up a little more room.
MoundMedic7
